How do I access router details
ViscountViktor
I was with TalkTalk, and on their router page it had a long list of my broadband information, including SN Margin, Line Attenuation, Max Line speed etc.
Is that information available on the Plusnet router or not? I can't seem to find it. Only throughput speeds.
DS
Fixes: 8
Re: How do I access router details
If it's a Plusnet Hub One, then this should help - click me
(not sure if it will work on earlier routers)
ViscountViktor
Thank you very much Smiley
DS
Fixes: 8
No problem Smiley
Should you ever want to post any of that information up on these forums, I would suggest you leave out 1, 2, 12, 13, 17 and 22.
