How can Plus.Net help me?
Poggers001
I would love to upgrade to Fibre but the service isn't available @ EN3 7GJ.
How can Plus.Net help make this service available in my area please?
Thanks Smiley
Lewis
Blake
Re: How can Plus.Net help me?
The truth is they can't but you can register your interest at www.superfast-openreach.co.uk and popping in your phone number in the when can i get it section and then scrolling to the bottom and pressing find out more on the register your interest section,  fill out the form and they will keep you up to date and it helps them know where there is demand Smiley
Poggers001
Thank you!
I have done just that. My area is enabled but my cabinet is not connected so fingers crossed.
Blake
No problem Wink
It sounds as if you will get it at some point not too far away, getting neighbours etc to fill the form out may help also..could be worth doing so OR know it's worth enabling your cabinet Smiley
