How can I let PlusNet know that my download speeds are much slower than BT Infinity?
eventoftheyear
I have recently switched from BT Infintity Full Fibre to PlusNet Full Fibre.  The cabinet is still the same distance away - I can see it from the bedroom window; it uses the same copper cable as before - the only difference is I've swapped the BT Home Hub for the PlusNet version.
In the past - when I used PlusNet before - you would raise a ticket - now you have to rely on an online chat or by phone, so sorry PlusNet - its a public question because I can't see another way.
I also have a SamKnows Whitebox - a Broadband monitoring tool - I'm part of the community that measures speed, so I have speed comparisons for the last 365 days in graph form.
Download Speed last 365 days - guess when I swapped provider?
Upload Speed - last 365 days
DNS response Times - last 365 days - guess where I changed provider !!!
UDP Latency - last 365 days
Fixes: 193
Re: How can I let PlusNet know that my download speeds are much slower than BT Infinity?
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 78.7 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Voice fault suspected - contact Voice CP to progress copper issue
Bridge Tap Not Detected
Estimated Line Length In Metres 250.5
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Sync speeds seem fine, however testing your line shows there may be a problem with the phone line.
Just looking in to the phone side of things now.
EDIT: I've raised a phone fault for you. The initial test against the phone line found a fault that shouldn't need an engineer to access your property. I've left a ticket on your account regarding this.
Just in regards to your comments about raising tickets, you can still raise faults via the member centre at http://faults.plus.net Smiley
 Harry Beesley
nigelmercier
You can still raise faults, but nothing else. It is very frustrating.
Just in regards to your comments about raising tickets, you can still raise faults via the member centre ...
eventoftheyear
Thank you for taking the time to test the line and raise the fault with BT - much appreciated.
