House move and legacy product
- House move and legacy product
- « Previous
- 1
- 2
- Next »
Re: House move and legacy product
16-01-2017 9:17 AM - edited 16-01-2017 9:20 AM
Hi Anoush,
The engineer just left.
He found no fault with the line and did the reset. However my speeds are unchanged at 40/2 even when plugged into the master test socket. This was tested on wired and wireless.
I did a speed test while he was here to show him and he said that it was syncing at the higher speed so its down my ISP limiting my speed. (It was already syncing at the higher speed since 6th Jan and I did mention this to him when he first arrived).
Please can you check if my connection is still banded or does the reset take time to work?
rk508
16-01-2017 11:04 AM
I think this may be a profiling problem rather than banding. PlusNet need to check for a profile mismatch in the BT systems which can happen, the profile has failed to update after your increase in sync speed. I don't think the engineer did a full DLM reset because they are not supposed to if no physical fault has been found and fixed. But it isn't the ISP limiting your speed it's BT's profile. Best of luck getting this sorted.
16-01-2017 12:00 PM
16-01-2017 12:01 PM
Just testing your broadband, and there's no profile info showing. One of my faults colleagues has advised me this can occur if a reset is in progress.
17-01-2017 8:42 AM
Hi Anoush/Matthew,
Last night I ran some speed tests and found that my speeds are now corresponding to my product and sync rate of 55/10.This happened without a restart of my router.
Out of interest what was the fix for this, was it the engineers reset that took some time or something else?
In any case thanks for all your help on this
rk508
17-01-2017 9:03 AM
Yeah, I believe the reset just took its time to go through.
08-03-2017 1:19 PM
Hi Anoush
I've just received an email to say that I will be charged for the engineers visit in January.
I'm curious as to why this is because I thought my line was banded and he did a reset? My download and upload speeds certainly increased a few hours after he left, so doesn't that mean there was an issue and it got fixed?
Can you let me know how I can dispute this?
rk508
08-03-2017 1:49 PM
Hi there, I'm sorry to hear of the charge. Discussing this with my manager we're unsure as to why we're charging you for the visit because it's clear that the service was banded to 40/2 before the visit and then correctly at 55/10 afterwards.
I've arranged for the fee to be written off. Apologies for this.
- « Previous
- 1
- 2
- Next »
