Home Hub One blocking legitimate IP addresses
- Home Hub One blocking legitimate IP addresses
25-06-2019 8:43 PM
Been having problems with connections from both my partner's and my own MacBooks. Despite having a strong wifi signal, there is no connection to email or web services for up to 20 - 40 seconds.
From event log this evening:
20:13:00, 25 Jun. OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [192.168.1.10]:63097->[212.227.15.138]:993 on ppp3). This is 1and1.co.uk IMAP server.
The hub firewall is also blocking these and other seemingly legitimate IP addresses:
2.16.56.159 -> a2-16-56-159.deploy.static.akamaitechnologies.com
104.78.178.30 -> a104-78-178-30.deploy.static.akamaitechnologies.com
17.253.37.205 -> uklon6-vip-bx-005.aaplimg.com
Anyone have an idea or suggestion?
Re: Home Hub One blocking legitimate IP addresses
25-06-2019 9:01 PM
Hi there.
It's possible that the router's firewall blocking traffic is a red herring and may not be related to your wireless signal dropping. Could you give the steps Here a go letting us know how you get on?
25-06-2019 9:05 PM
Thanks Gandalf
My networks are already separate. Two phones and 3 Macs are on 5GHz, with ROKU 2 on 2.4GHz with separate SSIDs
The Mac's wifi icon always shows a good connection when this happens.
25-06-2019 9:33 PM
Thanks for that @futurethomas.
When the issue occurs, are you able to log in to the router via 192.168.1.254?
25-06-2019 9:34 PM
Not for the same 20 - 40 seconds
25-06-2019 9:46 PM
Thanks for confirming that for us.
Are you able to connect the Macs to the 2.4 to see if we can replicate the issue there?
25-06-2019 9:49 PM - edited 25-06-2019 9:49 PM
Thanks Gandalf. I'll give that a go on my MacBook tomorrow and let you know what happens.
