High pings
rongtw
Fixes: 12
High pings
ok , last few days browsing has been worse than normal , and still getting bad tests from TBB single thread Sad
so have jumped gateway few times but nothing seams to help  , have factory reset router ASUS and started from fresh
TBB test same as in my previous thread https://community.plus.net/t5/Fibre-Broadband/Odd-TBB-test/td-p/1393324
so for a change thought would try DSL reports test , its worse Sad  ping was 400 grade F
http://www.dslreports.com/speedtest/17221032
gateway pcn-bng01.
5 REPLIES 5
St3
Aspiring Champion
Fixes: 5
Re: High pings
Ive just updated my router check and see if yours need updated, just incase Wink
rongtw
Fixes: 12
Re: High pings
did it this morning Ste Thumbs_Up
Fixes: 1,599
Re: High pings
Testing your line is pretty much showing everything is perfect...
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Radio Frequency Ingress Detected
Cross Talk Not Detected
Estimated Line Length In Metres 76.4
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Interference Observed In Days 5
Technology VDSL
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-06-09T12:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 79.9 Mbps 80.0 Mbps 79.9 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 763.0 Sec 900.0 Sec 899.6 Sec
Retrains 0.0 4.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2017-06-22T11:46:11.123+01:00 2017-06-22T12:01:11.123+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Mind running a traceroute for us?
rongtw
Fixes: 12
Re: High pings
@Gandalf Thanks Thumbs_Up
i must have one of them intermittent gremlins  Crazy
Fixes: 1,599
Re: High pings
No problems.
Intermittent issues can be quite pesky.
