High ping times in evening to specific server.
nbk
Hi.
In the evenings since some time last week ping times to a host in france which i connect to for things that require low ping (ok...it's gaming Smiley) have been very high, 150-200ms. Usually it's around 16-22ms and I have no problems on the old network.
The new network however seems to use different routing into the hosts network and from around 7-8pm till 10-11pm the ping times go quite high.
  7    12 ms    12 ms    12 ms  core1-BE1.southbank.ukcore.bt.net [195.99.125.130]
  8    13 ms    14 ms    13 ms  peer1-et-10-1-0.telehouse.ukcore.bt.net [195.99.127.3]
  9  139 ms  138 ms  135 ms  be100-104.ldn-1-a9.uk.eu [178.33.103.232]
10    19 ms    18 ms    17 ms  be11-1187.rbx-g1-a9.fr.eu [91.121.128.86]
So yes it's just between hops 8 and 9 where the issue lies...is that a problem with BT's network or the hosts network or both and is there anything plus can do about it? Smiley
New network woes...different routing...sigh Smiley
Fixes: 4
Re: High ping times in evening to specific server.
Quote from: nbk
Errrm, NOPE !
The ONLY hop which matters is the final one,  i.e. the host which you are trying to communicate with.
Each line of the traceroute just shows the individual reply time (to PING requests) from each router along the path, back to your PC.
The PING latency along the route is not cumulative, so it doesn't matter that on your hop#9 takes a little longer - it just means that particular device is a bit slow to respond to PING requests and doesn't necessarily mean that that device will also be slow at processing your traffic.
If all following hops (after #9) were also similarly slow, then that would provide an indication that the connection to hop#9 is either slow, or perhaps is a long distance away, but they aren't - so don't worry about it !.
What is the domain name (or IP address) of the the host you are trying to reach ? - so others here can also try tracerouting to it.
nbk
except that the high ping times on that hop coincide with high ping times to the game server
outside of the specified times both pings to that hop and the game server are fine
also the server has disabled ICMP so any hops after what I've pasted will time out but if you want a go it's
play.fragdeluxe.com
*edit*
and it's back to normal
...till tomorrow evening
Fixes: 4
I get this -
> mtr play.fragdeluxe.com
                                        Loss%  Snt  Last  Avg  Best  Wrst StDev
  1. my-home-gateway                    0.0%    10    2.7  2.4  1.8  4.0  0.7
  2. lo0-central10.ptn-ag02.plus.net    0.0%    10  31.2  21.4  13.6  40.4  10.1
  3. link-b-central10.ptn-gw02.plus.net  0.0%    10  24.8  25.8  23.9  30.3  2.1
  4. xe-1-2-0.ptw-cr02.plus.net          0.0%    10  26.1  30.8  23.1  64.1  13.4
  5. ae2.ptw-cr01.plus.net              0.0%    10  23.7  25.0  23.1  27.4  1.6
  6. ???                                100.0    10    0.0  0.0  0.0  0.0  0.0
  7. be11-1188.rbx-g2-a9.fr.eu          0.0%    10  32.7  30.0  27.9  37.3  2.9
  8. vac1-0-a9.fr.eu                    0.0%    10  30.3  29.9  28.1  32.4  1.6
  9. vac1-1-n7.fr.eu.firewall            0.0%    10  28.8  28.5  27.3  29.9  0.8
10. vac1-2-n7.fr.eu.tilera              0.0%    10  27.9  28.4  27.4  30.3  1.0
11. vac1-3-n7.fr.eu                    0.0%    10  27.7  31.2  27.6  55.2  8.6
12. ???                                100.0    10    0.0  0.0  0.0  0.0  0.0
13. ???                                100.0    10    0.0  0.0  0.0  0.0  0.0
14. ???                                100.0    10    0.0  0.0  0.0  0.0  0.0
15. be50-5.gra-3a-a9.fr.eu              0.0%    10  28.8  30.0  27.8  32.4  1.5
16. ???                                100.0    10    0.0  0.0  0.0  0.0  0.0
Next time it's bad, reply to this thread, and see if anyone can give you an alternative trace for comparison.
nbk
Yeah Nibiru you're on the old network so taking a different route
Fixes: 4
But presumably that just means that all my traceroutes will be slower than yours, but I should still see the large variations in latency you are describing beyond the Plusnet/BT routers ?.
Fixes: 162
Niburu is correct in that it's only the last hop that shows you the latency to that server. It's likely that the devices along the way aren't set up to prioritise replies to ping traffic, so the response times on those are higher.
 Chris Parr
 Plusnet Staff
nbk
It's still more than coincidental that high pings to the destination server coincide exactly with high pings on that hop though...ho hum Smiley
nbk
Ah well, pings been on the rise again since ~7.30pm...it's very odd Smiley
Fixes: 4
Looks OK to me -
  1. my-home-gateway                    0.0%    10    5.4  2.6  1.9  5.4  1.2
  2. lo0-central10.ptn-ag02.plus.net    0.0%    10  13.8  17.7  13.7  35.7  7.0
  3. link-b-central10.ptn-gw02.plus.net  0.0%    10  24.2  25.7  23.4  31.1  2.3
  4. xe-1-2-0.ptw-cr02.plus.net          0.0%    10  23.4  27.1  23.4  52.0  8.8
  5. ae2.ptw-cr01.plus.net              0.0%    10  36.7  26.3  23.7  36.7  3.9
  7. be11-1188.rbx-g2-a9.fr.eu          0.0%    10  28.9  29.1  27.2  31.3  1.2
  8. vac1-0-a9.fr.eu                    0.0%    10  28.6  29.6  27.9  35.3  2.4
  9. vac1-1-n7.fr.eu.firewall            0.0%    10  29.1  28.8  27.2  35.1  2.3
10. vac1-2-n7.fr.eu.tilera              0.0%    10  29.3  28.7  27.3  32.0  1.6
11. vac1-3-n7.fr.eu                    0.0%    10  27.4  29.2  27.4  36.3  2.8
15. be50-5.gra-3a-a9.fr.eu              0.0%    10  27.7  29.6  27.7  31.0  1.1
nbk
Yeah Nibiru, yours is taking a different route on the old network :/
 4  172.17.7.45 (172.17.7.45)  8.931 ms  9.104 ms  9.095 ms
5  172.17.11.166 (172.17.11.166)  13.320 ms  13.313 ms  13.742 ms
6  be2.psb-ir01.plus.net (195.166.129.180)  13.020 ms  12.122 ms  12.476 ms
7  core1-BE1.southbank.ukcore.bt.net (195.99.125.130)  13.047 ms  13.022 ms  13.014 ms
8  peer1-et-2-1-0.telehouse.ukcore.bt.net (62.172.103.25)  13.440 ms  13.501 ms  13.491 ms
9  be100-104.ldn-1-a9.uk.eu (178.33.103.232)  119.469 ms  119.517 ms  118.659 ms
10  be11-1187.rbx-g1-a9.fr.eu (91.121.128.86)  16.999 ms  17.186 ms  16.918 ms
11  * * vac1-0-a9.fr.eu (178.33.100.149)  678.286 ms
12  vac1-1-n7.fr.eu.firewall (178.33.100.152)  16.882 ms  16.691 ms  16.680 ms
13  vac1-2-n7.fr.eu.tilera (37.187.36.245)  16.933 ms  17.218 ms  16.601 ms
14  vac1-3-n7.fr.eu (91.121.215.13)  16.989 ms  16.757 ms  17.692 ms
The rising pings to the server do coincide with that 9th hop rising too so i dont know
Fixes: 4
It is very odd that we both go via  "vac1-0-a9.fr.eu"  but your pings are massively different from mine on that hop !  Crazy
nbk
interestingly before you hit VAC (which is OVH's DDoS protection) you're routing through
whereas i'm hitting
Looks like it's really in OVH's network then, ho hum Smiley
nbk
Also, this is an annoyance with the new network...
Seemingly permanently connected to the same gateway on the same IP subnet so you can't gateway hop to see if you can get a better connection...
The old network was seemingly better for my needs :p
