High ping times in evening to specific server.
- Re: High ping times in evening to specific server.
15-03-2016 8:30 PM
In the evenings since some time last week ping times to a host in france which i connect to for things that require low ping (ok...it's gaming :)) have been very high, 150-200ms. Usually it's around 16-22ms and I have no problems on the old network.
The new network however seems to use different routing into the hosts network and from around 7-8pm till 10-11pm the ping times go quite high.
7 12 ms 12 ms 12 ms core1-BE1.southbank.ukcore.bt.net [195.99.125.130]
8 13 ms 14 ms 13 ms peer1-et-10-1-0.telehouse.ukcore.bt.net [195.99.127.3]
9 139 ms 138 ms 135 ms be100-104.ldn-1-a9.uk.eu [178.33.103.232]
10 19 ms 18 ms 17 ms be11-1187.rbx-g1-a9.fr.eu [91.121.128.86]
So yes it's just between hops 8 and 9 where the issue lies...is that a problem with BT's network or the hosts network or both and is there anything plus can do about it?
New network woes...different routing...sigh
15-03-2016 9:06 PM
Quote from: nbk it's just between hops 8 and 9 where the issue lies
Errrm, NOPE !
The ONLY hop which matters is the final one, i.e. the host which you are trying to communicate with.
Each line of the traceroute just shows the individual reply time (to PING requests) from each router along the path, back to your PC.
The PING latency along the route is not cumulative, so it doesn't matter that on your hop#9 takes a little longer - it just means that particular device is a bit slow to respond to PING requests and doesn't necessarily mean that that device will also be slow at processing your traffic.
If all following hops (after #9) were also similarly slow, then that would provide an indication that the connection to hop#9 is either slow, or perhaps is a long distance away, but they aren't - so don't worry about it !.
What is the domain name (or IP address) of the the host you are trying to reach ? - so others here can also try tracerouting to it.
15-03-2016 9:13 PM
outside of the specified times both pings to that hop and the game server are fine
also the server has disabled ICMP so any hops after what I've pasted will time out but if you want a go it's
play.fragdeluxe.com
*edit*
and it's back to normal
...till tomorrow evening
15-03-2016 10:11 PM
> mtr play.fragdeluxe.com
Loss% Snt Last Avg Best Wrst StDev
1. my-home-gateway 0.0% 10 2.7 2.4 1.8 4.0 0.7
2. lo0-central10.ptn-ag02.plus.net 0.0% 10 31.2 21.4 13.6 40.4 10.1
3. link-b-central10.ptn-gw02.plus.net 0.0% 10 24.8 25.8 23.9 30.3 2.1
4. xe-1-2-0.ptw-cr02.plus.net 0.0% 10 26.1 30.8 23.1 64.1 13.4
5. ae2.ptw-cr01.plus.net 0.0% 10 23.7 25.0 23.1 27.4 1.6
6. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
7. be11-1188.rbx-g2-a9.fr.eu 0.0% 10 32.7 30.0 27.9 37.3 2.9
8. vac1-0-a9.fr.eu 0.0% 10 30.3 29.9 28.1 32.4 1.6
9. vac1-1-n7.fr.eu.firewall 0.0% 10 28.8 28.5 27.3 29.9 0.8
10. vac1-2-n7.fr.eu.tilera 0.0% 10 27.9 28.4 27.4 30.3 1.0
11. vac1-3-n7.fr.eu 0.0% 10 27.7 31.2 27.6 55.2 8.6
12. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
13. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
14. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
15. be50-5.gra-3a-a9.fr.eu 0.0% 10 28.8 30.0 27.8 32.4 1.5
16. ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
Next time it's bad, reply to this thread, and see if anyone can give you an alternative trace for comparison.
15-03-2016 10:18 PM
15-03-2016 10:27 PM
16-03-2016 9:15 AM
16-03-2016 9:29 AM
16-03-2016 8:20 PM
16-03-2016 8:25 PM
1. my-home-gateway 0.0% 10 5.4 2.6 1.9 5.4 1.2
2. lo0-central10.ptn-ag02.plus.net 0.0% 10 13.8 17.7 13.7 35.7 7.0
3. link-b-central10.ptn-gw02.plus.net 0.0% 10 24.2 25.7 23.4 31.1 2.3
4. xe-1-2-0.ptw-cr02.plus.net 0.0% 10 23.4 27.1 23.4 52.0 8.8
5. ae2.ptw-cr01.plus.net 0.0% 10 36.7 26.3 23.7 36.7 3.9
7. be11-1188.rbx-g2-a9.fr.eu 0.0% 10 28.9 29.1 27.2 31.3 1.2
8. vac1-0-a9.fr.eu 0.0% 10 28.6 29.6 27.9 35.3 2.4
9. vac1-1-n7.fr.eu.firewall 0.0% 10 29.1 28.8 27.2 35.1 2.3
10. vac1-2-n7.fr.eu.tilera 0.0% 10 29.3 28.7 27.3 32.0 1.6
11. vac1-3-n7.fr.eu 0.0% 10 27.4 29.2 27.4 36.3 2.8
15. be50-5.gra-3a-a9.fr.eu 0.0% 10 27.7 29.6 27.7 31.0 1.1
16-03-2016 8:38 PM
4 172.17.7.45 (172.17.7.45) 8.931 ms 9.104 ms 9.095 ms
5 172.17.11.166 (172.17.11.166) 13.320 ms 13.313 ms 13.742 ms
6 be2.psb-ir01.plus.net (195.166.129.180) 13.020 ms 12.122 ms 12.476 ms
7 core1-BE1.southbank.ukcore.bt.net (195.99.125.130) 13.047 ms 13.022 ms 13.014 ms
8 peer1-et-2-1-0.telehouse.ukcore.bt.net (62.172.103.25) 13.440 ms 13.501 ms 13.491 ms
9 be100-104.ldn-1-a9.uk.eu (178.33.103.232) 119.469 ms 119.517 ms 118.659 ms
10 be11-1187.rbx-g1-a9.fr.eu (91.121.128.86) 16.999 ms 17.186 ms 16.918 ms
11 * * vac1-0-a9.fr.eu (178.33.100.149) 678.286 ms
12 vac1-1-n7.fr.eu.firewall (178.33.100.152) 16.882 ms 16.691 ms 16.680 ms
13 vac1-2-n7.fr.eu.tilera (37.187.36.245) 16.933 ms 17.218 ms 16.601 ms
14 vac1-3-n7.fr.eu (91.121.215.13) 16.989 ms 16.757 ms 17.692 ms
The rising pings to the server do coincide with that 9th hop rising too so i dont know
16-03-2016 8:48 PM
16-03-2016 9:53 PM
whereas i'm hitting
Looks like it's really in OVH's network then, ho hum
16-03-2016 10:14 PM
Seemingly permanently connected to the same gateway on the same IP subnet so you can't gateway hop to see if you can get a better connection...
The old network was seemingly better for my needs 😛
