High packet loss and reduced connection speed since evening of 2018-09-09
- Re: High packet loss and reduced connection speed ...
10-09-2018 8:44 PM
Re: High packet loss and reduced connection speed since evening of 2018-09-09
11-09-2018 12:04 PM - edited 11-09-2018 12:18 PM
Hi @froodulous,
I've taken a look into your account today and I can see that the connection appears to be frequently dropping out, however upon testing your line, we're unable to detect any external causes for this issue. As this is the case we'll need you to make sure that a fault hasn't developed with any of the internal equipment within the property before we progress the investigation of this fault any further and I would recommend following our online troubleshooting guides for this, which can be found here and here.
The latter link will walk you through how to setup your router within the test socket in your property and this is one o the best methods we can use to determine the location of the fault.
Please let us know how this goes and if you continue to experience any further issues after carrying out the troubleshooting steps so that we can investigate further if needs be.
11-09-2018 12:16 PM
@TheMightyAJ There's a problem with the second link.
11-09-2018 12:19 PM
Thanks for pointing this out @Strat! This has been corrected now.
11-09-2018 6:20 PM
12-09-2018 10:41 AM
Hi @froodulous,
Thank you for the update, I'm glad to hear that your connection looks to have returned to normal now. Please let us know if you experience any further connection issues or if there's anything else that you'd like to discuss.
