High packet loss and other DNS issues
- High packet loss and other DNS issues
Re: High packet loss and other DNS issues
24-09-2016 7:08 PM
@chenks76 The problem we were seeing affected both ADSL and FTTC however following the work we did yesterday morning we are hopeful the problem has gone away so I would assume that if you are seeing any issues then it is unrelated the packet loss problem described in this thread.
@puglord1973 Yeah the work on this is complete, while we are keeping a very close eye on things we aren’t seeing any further packet loss.
@shevek I often see this as well so it’s not impossible. There’s two main reasons for this, the first is that if you max out your downstream with a download then anything else coming down could be fighting out alongside it. While I’m traffic management system is designed to prioritise some traffic over others (for example both gaming and ping get the highest priority) if they are equal (which can sometimes happen with a game download) then you could see increased latency and loss. The second is that your upload speed is also maxed out, this often happens with P2P but can also happen with other downloads depending on your upload speed. A 40Mbps download can easily be sending 0.5Mbps of upload ack packets so doesn’t take a huge amount more to max out the upload.
Plusnet Technology
24-09-2016 7:36 PM
@chenks76 wrote:
well i'm only on ADSL (around 13Mbps), but trying to work out if this problem affects us ADSL users too.
mostly streaming radio from iplayer all day.
i was moved over the new network a while ago (and i have a static IP).
Seems bad for just streaming radio.
As it's a new TBB monitor you've yet to see what it's like overnight. Even what is being pinged could make a difference if it's rubbish at answering quickly. If the graph looks like that always maybe start doing -
ping -n 100 8.8.8.8 multiple times from a wired PC to see if the results are as bad as the graph.
24-09-2016 7:45 PM
I get 32 down and 1.8 up - I'm limited to 2 up as per the package, my line actually supports ~7.5 up. I was a bit miffed when I realised this, after the 14 day cool off. My own fault for not reading it properly
24-09-2016 8:06 PM - edited 25-09-2016 9:09 AM
Live link for static ip (ptw-bng01) in case it is any use. 3 packet loss spikes today (Sat). These are the first I've seen since the one at 05.30 Fri when you completed the work you referred to.
Sat 24th
24-09-2016 9:14 PM - edited 24-09-2016 9:17 PM
24-09-2016 10:04 PM - edited 25-09-2016 8:57 AM
24-09-2016 10:54 PM - edited 24-09-2016 10:54 PM
@dave How can you say no packet loss today when I've had it all day since the work was done. Not had this all week but getting it all day today! Will reboot router in the morning for a new IP address and see what happens.
25-09-2016 4:47 AM - edited 25-09-2016 11:25 AM
@dave I don't know why it keeps happening every few days, but live graph posted on Friday seems to have stopped updating at midnight again.
New live graph
On Friday and Saturday, there seems to be a noticeable increase in latency spikes following Friday morning's maintenance. It doesn't affect how we use our internet connection (mainly streaming video) though. ie. The live graph previously looked a lot quieter with upstream going via Southbank.
Here is an example from the 17th
25-09-2016 7:55 AM - edited 25-09-2016 8:04 AM
looks like plusnet as some work still to do.
here's my graph's from today.
25-09-2016 11:08 AM
25-09-2016 11:26 AM
No.way should I have to pay for this.
I want out.
25-09-2016 11:39 AM
My service has improved greatly in terms of the connection / packet loss (not perfect but finally usable after my initial support ticket from 31st July). I now intend to write to:
Customer Relations
Plusnet PLC
The Balance
2 Pinfold Street
Sheffield
South Yorkshire
S1 2GU
I will be asking what will be done to compensate me for nearly 20+ days of unusable internet (stuttering video and unplayable games).
25-09-2016 11:50 AM
25-09-2016 11:59 AM
Using his own equipment he was able to achieve downstream & upstream speeds of what I used to get before all these issues began, however using my home PC (wired) and other devices (wireless) we still were not able to recreate the speeds he got with his own equipment.
My downstream speeds now are slightly better than they were before he fixed the faults outside, I can now get around 27/28mbps as before it was around 23/24mbps. Its still not what I had previously though.
Looking at my router he noticed a light that was flashing green which he said should stay solid green, he then said I should talk with PN about getting a new router. As soon as the engineer left I went straight on to live chat and spoke with a guy, which seemed very pleasant & helpful. He was very apologetic for the issues that I had & helped me get a new router ordered which I hope will get me back to normal speeds when it arrives this week.
The packet loss issue seems to have mostly been resolved for me. Doing ping tests, I seemed to get good results & I no longer seem to get lag or rubber banding whilst gaming. Streaming also seems a lot smoother than previous weeks.
I have a couple of questions about TBB graphs using Hub zeros or Hub ones via DMZ.
1. Because you are relying on a wireless connection to do the pings will it show packet loss as a false positive so to speak? Can this show more packet loss than you are actually getting?
2. What is acceptable in regards to the yellow latency spikes? Do they become high whilst internet is being used alot at home and can this also be higher because its connected wirelessly via DMZ?
25-09-2016 12:19 PM - edited 25-09-2016 12:20 PM
It doesn't have to be a wireless device in the DMZ. My TBB graph is from my Playstation 4 which is connected via an ethernet cable into my Hub Zero. I've managed to do a graph from my youview box which is connected via powerline adapters which go via ethernet too. I don't get as good a plot from the youview box so I guess what you put in the DMZ can affect the outcome of the plot. Not sure about the yellow spikes, someone with a bit more knowledge will hopefully answer that one.
