High packet loss and other DNS issues
- Re: High packet loss and other DNS issues
25-09-2016 12:48 PM
Surely I can cancel my service.. Why did they accept my order knowing that they were having issues.
4 weeks with plus net and service has been shocking.
25-09-2016 12:54 PM
this is my last 24 hours or so
static IP ADSL
25-09-2016 12:55 PM
That is why I have been using chromecasts for my TBB graph.
I will try changing the DMZ to my dekstop though when I get from work.
25-09-2016 2:00 PM - edited 25-09-2016 2:09 PM
Wireless can be quite variable for ping time and loss.
Edit: Yes yellow spikes can be uploading/downloading. What is normal is a bit hard to say and depends on your up and down connection speeds and the size of the buffers in the modem/modem router.
25-09-2016 2:08 PM
The recent change as upset the game I go into the character moves in sort of slow motion with starting and stopping at any time of day, so static IP not the cure for everything.
25-09-2016 4:48 PM - edited 25-09-2016 4:49 PM
well this is not good !
You are currently connected to gateway ptw-bng01.
This is located in Telehouse West.
static IP
25-09-2016 5:00 PM - edited 25-09-2016 5:00 PM
@chenks76 I am on a static UP and on the same gateway and I'm not seeing the same:
25-09-2016 5:01 PM
25-09-2016 5:31 PM - edited 25-09-2016 5:38 PM
well just for comparison am on the OLD network , Static IP
http://www.thinkbroadband.com/ping/share/ddd0696d0d671a5d51464da938a0b08b-25-09-2016.html
25-09-2016 5:44 PM
@rongtw AFAIAA Telehouse West is on the old network
25-09-2016 5:52 PM
well i was moved to the new network at the very start.
i was PMd by plusnet to get moved over as one of the first test users in scotland.
this is my current status
25-09-2016 6:15 PM
25-09-2016 6:17 PM - edited 25-09-2016 6:18 PM
@shevek was saying that telehouse west was the old network, when clearly it can't be, as i'm on the new network and on telehouse west, so it must be on both.
25-09-2016 6:34 PM
25-09-2016 6:37 PM - edited 25-09-2016 6:49 PM
Anyone from plusnet going to even bother looking into my issue????
