High packet loss and other DNS issues
watercooled
Re: High packet loss and other DNS issues
And plus net go quiet again. .
Surely I can cancel my service.. Why did they accept my order knowing that they were having issues.
4 weeks with plus net and service has been shocking.
chenks76
All Star
Fixes: 12
this is my last 24 hours or so
static IP ADSL
92d70ea7f49c6b5136a6ad50affbcf97-25-09-2016
MUFFiN
Thanks for the reply @Paul_Corfield, unfortunately for me, the only device that I have in my house that is wired is my PC. I'm not sure if that will work though as maybe the computer firewall will block the incoming pings thinking it is dangerous?
That is why I have been using chromecasts for my TBB graph.
I will try changing the DMZ to my dekstop though when I get from work.
legume
Wireless can be quite variable for ping time and loss.
Edit: Yes yellow spikes can be uploading/downloading. What is normal is a bit hard to say and depends on your up and down connection speeds and the size of the buffers in the modem/modem router.
dnpark38
The recent change as upset the game I go into the character moves in sort of slow motion with starting and stopping at any time of day, so static IP not the cure for everything.
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
chenks76
All Star
Fixes: 12
well this is not good !
You are currently connected to gateway ptw-bng01.
This is located in Telehouse West.
static IP
shevek
@chenks76 I am on a static UP and on the same gateway and I'm not seeing the same:
My Broadband Ping - Plusnet static
chenks76
All Star
Fixes: 12
well i am !
rongtw
Fixes: 12
well just for comparison  am on the OLD network , Static IP
http://www.thinkbroadband.com/ping/share/ddd0696d0d671a5d51464da938a0b08b-25-09-2016.html
shevek
@rongtw AFAIAA Telehouse West is on the old network
chenks76
All Star
Fixes: 12
well i was moved to the new network at the very start.
i was PMd by plusnet to get moved over as one of the first test users in scotland.
this is my current status
rongtw
Fixes: 12
shevek YES thats  what i said ,, Thumbs_Up   just posted for comparison
chenks76
All Star
Fixes: 12
@shevek was saying that telehouse west was the old network, when clearly it can't be, as i'm on the new network and on telehouse west, so it must be on both.
watercooled
I'm now getting 5mb on fibre
watercooled
Anyone from plusnet going to even bother looking into my issue????
