High Ping Spikes in Game
- High Ping Spikes in Game
30-09-2019 9:42 AM
Morning,
Over the past month I have ping spikes in all online games, on avg its around 40ms but spikes to over 500 and settles right back down. will do this every few mins throughout the game. I have tried everything I can find on the forum.
PC is connected via Wifi (5GHz) separate channel, though did try via cable and was still the same.
Changed the router to BTHub6 again no difference other than better wifi connection.
Bought Static IP again no difference.
It does this anytime of the day regardless of anyone else on the network.
Running out of ideas as changed every setting on router back n forth with no luck.
Any suggestions welcome, this started about 4 weeks ago was fine up to this point.
Re: High Ping Spikes in Game
30-09-2019 2:56 PM - edited 30-09-2019 3:00 PM
Hi @Cordwe11,
I'm sorry that you're experiencing ping spikes and for any inconvenience that this is causing. Thank you for confirming that this occurs on both wired and wireless connections and that changing to a different router didn't help.
I've tested your line but the test hasn't picked up the cause from here:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 60.4 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 496.7 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Good | ||||
Interference Pattern | Regular Interference Observed on Weekends | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | From20:00to20:15 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 2 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
DP Type | External | ||||
Profile Name | 0.128M-80M Downstream 5dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-09-17T15:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 63.8 Mbps | 67.8 Mbps | 65.2 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 892.6 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-09-30T13:30:49Z | 2019-09-30T13:45:49Z |
Ingress Code Violation | 1 | 3 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
We'll need to do some further troubleshooting to try and narrow down the cause. If you've not done so already, I'd recommend starting with basic checks here. If these checks don't resolve the problem, the next step would be to connect your router directly to the test socket, which is under the faceplate of your master socket and seeing if the connection stabilises. This rules out internal wiring, face plates and extension sockets as being the cause. Please see the following guide for instructions on how to connect to the test socket. https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Please let us know how you get on.
30-09-2019 3:10 PM
Hi thank you for looking into this for me, The router is connected to the test socket, I have done all the basic tips.
Ive tried changing micro filter as well, Speeds are good, just started getting lag spikes. was same on console as well as PC.
Get some screen shots this evening.
30-09-2019 6:48 PM
Thanks for updating us, @Cordwe11.
Please do get us those screenshots - As we're not detecting any sort of an issue they'll be invaluable in helping us to determine what's going on.
If you haven't already, please also raise the issue over at faults.plus.net, letting us know here when you've done so to enable us to progress the issue.
