High Latency reading
- High Latency reading
24-03-2016 11:47 AM
I currently have a standard broadband fibre connection and having performed a number of speed tests using Speedsmart on my iPad note the Latency reading is always around 800. The download figure is around 35 and upload around 2. I seem to recall that when it was first installed it was well below 100. Does this mean I have a problem and if so can anybody advise a recommended solution?
Regards
Regards
Message 1 of 2
(526 Views)
1 REPLY 1
Re: High Latency reading
24-03-2016 11:48 AM
What results do you get using a wired device?
Wifi connections are not the best to test latency on due to the large amount of environmental factors that can affect the signal.
Message 2 of 2
(367 Views)
