Help
Help
on 05-01-2017 6:52 PM - last edited on 05-01-2017 7:06 PM by Mav
Not been on for a while now because my fibre has been running perfectly...you guessed it But
Had a disconnection today and I've gone from solid 20/68 to the attached photo
Got home from work and reconnected everything but it stayed the same please could a mod take a look and give me some advice..
Thank you
Moderator's note by Mike (Mav): Personal information removed from attachment in a public forum.
Re: Help
05-01-2017 7:02 PM
Moderators are customers like yourself and have no access to your account.
While waiting for a member of staff to pick this up other members may be able to offer advice.
Forum Moderator and Customer
Re: Help
05-01-2017 7:02 PM
Re: Help
05-01-2017 7:05 PM
No problem.
But please bear in mind that any editing you make to your posts should not include removal of mod notes as per Forum Rules.
Re: Help
06-01-2017 7:10 AM - edited 06-01-2017 7:11 AM
On a good note as far as I can tell it has remained connected since yesterdays reboot...
First reboot yesterday would have been the drop in speed and the second one at about 18:00/18:30 was me trying to re-set my settings any other disconnections if any were not done by me
Most of the time the connection and uptime say 50 to ninety plus days
I know you do get disconnected and re-connected but usually my stats stay @ 20/68
Thank you for any help
Re: Help
06-01-2017 3:52 PM
Or should I just report a fault...
Or do you think it was just a hiccup and the DLM will sort itself out over the next few days
Thank you any help
Re: Help
06-01-2017 4:51 PM
@scottymc wrote:
Hi any staff managed to look in to this ...
The official response time is 72 hours although forum staff sometimes pick things up quicker than that.
Re: Help
09-01-2017 7:27 AM
I rebooted the router Sunday morning and tried a different router and checked all connections ...
Hopefully staff could tell me if I need to report a fault...
Thank you
Re: Help
09-01-2017 4:42 PM
Re: Help
10-01-2017 7:23 AM - edited 10-01-2017 7:26 AM
I have reported this and there is a fault on the line chap at plusnet seems to think its from the box to the exchange .
So now the upto 72hour wait begins.
