Help with user name, account name.
- Re: Help with user name, account name.
- « Previous
- Next »
a week ago - last edited a week ago
I will have to rely on the routers firewall. If you could recommend a good replacement or inbetween router that I can buy that can be configured with the usaul settings that would be appreciated.
Again could you kindly explain how to reset my NAT setting, thanks
I also have to reset my password everytime I sign into my plusnet account so my email could also be compromised, so I have a lot to sort out but appreciate your help.
a week ago
No problem, the ProAddon isn’t a firewall, it’s explained in the article here https://www.plus.net/help/broadband/about-plusnet-pro-addon/
Failed payment is if you ever miss a bill or don’t pay we’d add a static IP on the account again though it’s just due to the way our failed billing process works internally.
I can’t recommend a replacement router or explain how to change your NAT type but other people on the forums may be able to assist with that.
a week ago
I will ask on the forum about a suitable replacement router, as the hub one is just to old and open to security breaches, if any will work, thank you.
- « Previous
- Next »
