Help with setting up router
jessie0045
I purchased the Asus RT-AV68U router today im trying to set it up which seems to be a lot of trouble.
All the right cables etc are used.
Has anyone used this router before, if so could they help me with the setup please?
If i plug my old router in it works fine
any help with the settings would be great
Many thanks
dnpark38
Re: Help with setting up router
Found this via Google might help.
http://www.7tutorials.com/reviewing-asus-rt-ac68u-router-possibly-fastest-router-you-will-ever-use
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
Fixes: 189
found the manual here, looking at the quick setup has it detected that it's ppoe?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
