Help understanding analysis
FIXED- Subscribe to RSS Feed
- Re: Help understanding analysis
26-04-2020 11:15 AM
INTERNAL **
KBD
Test Outcome Fail
Test Outcome Code GTC_FTTC_SERVICE_1613
Description Potential HR Joint detected on GEA service. Please continue to submit a trouble report
Main Fault Location CE
Sync Status In Sync
Downstream Speed 15.0 Mbps
Upstream Speed 6.0 Mbps
Appointment Required Y
Fault Report Advised Y
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 1098.4
Upstream Rate Assessment Very Good
Downstream Rate Assessment Low
Interference Pattern Regular Interference Observed Daily
Service Impact Retrains Observed
Interference Duration Longest Occurrence From12:15to16:45
Interference Location Customer Premise
Interference Observed In Days 4
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2020-04-23T16:00:00
GEA Test Detail
Fixed! Go to the fix.
26-04-2020 11:21 AM
It unlikely this would lead to a engineer charge.
26-04-2020 7:13 PM - edited 26-04-2020 7:29 PM
HR normally means in the electrical and radio world, a high resistance, caused by a bad connection on the line.
This may be due to moisture ingress at a junction, causing corrosion and increasing the resistance, causing issue with the phone & broadband systems.
Fixing requires the joint to be remade, and the junction box sealed agains moisture, followed by tests to ensure the issue has been resolved.
So
Main Fault Location CE looks like the fault may be at your property, if its Openreaches side of the connection box, its their problem and there should be no charge
Sync Status In Sync
Downstream Speed 15.0 Mbps Seems a bit low for your distance, hopefully the repair wil fix it,
https://www.broadbandchecker.btwholesale.com/#/ADSL is the site to check what speeds you should be getting.
Bridge Tap Not Detected Good
Radio Frequency Ingress Not Detected Good
Repetitive Electrical Impulse Noise Not Detected Good
Cross Talk Not Detected Good
Estimated Line Length In Metres 1098.4 Good
Interference Pattern Regular Interference Observed Daily Not Good
Interference Duration Longest Occurrence From12:15to16:45 Not Good, what is happening electrically in the house or garden during this time? Interference can be caused by lots of things, both man made and natural. Man made can be bad electrical connections, faulty or low standard electrical equipment, central heating systems
Interference Location Customer Premise Not Good
Home Wiring Problem Not Detected Good, so it may be on their portion of the line
My comments in bold
Please let us know how you got on.
26-04-2020 10:37 PM
I was wondering whether upgrading the firmware to the latest version would help as I’m currently on 4.7.5.1.83.8.227 which I think is quite old and other threads on the plusnet community say that this can cause major connection issues. Stressed out trying to work from home with poor to no wifi.
26-04-2020 10:58 PM
27-04-2020 6:39 AM
Is there an issue with the phone, ie crackling or other noise?
If the issue is the line then changing the firmware in the modem probsbley will not solve the issue,however you could
request Plusnet to force an update.
Re no wifi, that is another issue and is dependant on other things like the construction of the property, the band usage, ie are you in an area where there are lots more properties all using wifi?
There are comments on the community about splitting the bands, have a look around, as I do not use the Plusnet Hub except as a backup ot for problem solving.
27-04-2020 8:50 AM
27-04-2020 10:26 AM
Hi @mickyl
Sorry to hear about this ongoing issue. I can see that you have an engineer visit tomorrow. Let us know if you will still have any problems after this visit.
28-04-2020 9:03 PM
