Help of diagnosing my high error rates causing resyncs
- Help of diagnosing my high error rates causing res...
- « Previous
- Next »
Re: Help of diagnosing my high error rates causing resyncs
16-02-2018 11:45 AM
Ex-Broadband Service Manager
16-02-2018 12:08 PM
@Oldjim GEA test below for you.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 45.3 Mbps |
Upstream Speed | 8.5 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 711.6 |
Upstream Rate Assessment | Reasonable |
Downstream Rate Assessment | Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | ; 00:00 to 23:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 14 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-02-03T12:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 41.9 Mbps | 49.8 Mbps | 48.2 Mbps |
Up Stream Line Rate | 7.8 Mbps | 8.4 Mbps | 8.2 Mbps |
Up Time | 789.0 Sec | 900.0 Sec | 899.6 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-02-16T11:50:33Z | 2018-02-16T12:05:33Z |
Ingress Code Violation | 14 | 1 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
16-02-2018 1:56 PM - edited 16-02-2018 2:09 PM
Actual line speed 47,406 which is significantly higher than reported by the GEA Test and is a result of Retransmission High
How is the interference customer premises determined as opposed to just outside it which is the only overhead wire across the road from the pole and given that numerous checks have failed to identify any internal source on interference
Note that the actual line length is 800 metres
19-02-2018 8:09 AM - edited 19-02-2018 8:09 AM
I don't know what has happened but with no changes I am aware of I am now on over 9 days with no drop in sync
19-02-2018 2:34 PM
What are the line stats looking like now that it seems stable?
19-02-2018 2:40 PM
DSLAM/MSAN type: BDCM:0xa48c / v0xa48c Modem/router firmware: AnnexA version - A2pv6F039g1.d24m DSL mode: VDSL2 Profile 17a Status: Showtime Uptime: 9 days 16 hours 33 min 31 sec Resyncs: 0 (since 19 Feb 2018 10:12:28) Downstream Upstream Line attenuation (dB): 21.1 0.0 Signal attenuation (dB): Not monitored Connection speed (kbps): 47406 8471 SNR margin (dB): 3.8 4.7 Power (dBm): 12.8 5.0 Interleave depth: 4 1 INP: 52.00 0 G.INP: Enabled Not enabled Vectoring status: 5 (VECT_UNCONFIGURED) RSCorr/RS (%): 48.0160 0.5899 RSUnCorr/RS (%): 0.0000 0.0000 ES/hour: 0.23 1.36
19-02-2018 2:54 PM
The ES rate is almost zero now! Has someone quietly replaced the cable to the exchange? Looks just like you are on a brand new line.
Otherwise it's a mystery.
19-02-2018 5:12 PM
Just had a power cut and as usual my router restarted quicker than everyone else - this won't hold
Stats recorded 19 Feb 2018 17:08:32 DSLAM/MSAN type: BDCM:0xa48c / v0xa48c Modem/router firmware: AnnexA version - A2pv6F039g1.d24m DSL mode: VDSL2 Profile 17a Status: Showtime Uptime: 0 hour 1 min 13 sec Resyncs: 0 (since 19 Feb 2018 10:12:28) Downstream Upstream Line attenuation (dB): 21.1 0.0 Signal attenuation (dB): Not monitored Connection speed (kbps): 51817 10984 SNR margin (dB): 1.8 3.1 Power (dBm): 12.9 7.1 Interleave depth: 4 1 INP: 51.00 0 G.INP: Enabled Not enabled Vectoring status: 5 (VECT_UNCONFIGURED) RSCorr/RS (%): 1.5422 0.0068 RSUnCorr/RS (%): 0.0000 0.0000 ES/hour: 0.15 1.92
19-02-2018 7:21 PM
The downstream SNRM is well below the minimum specified. BT have only recently reduced SNRM from 6db to 3db as a theoretical minimum but yours is in the realms of instability (as you well know). To me this indicates a DLM fault of some sort, especially if it doesn't even try to regain at least 3db. There must be a way to get a DLM reset done surely? Even if it means getting a BT technician to visit. You have enough evidence to show that the line is unstable because of the DLMs failure to control at correct settings.
19-02-2018 7:28 PM
It's not a DLM fault, Oldjim's routed resynced quickly at the normal 6dB SNRM then other lines came back up creating noise and crosstalk resulting in a reduction in SNRM to a rather low level which will soon cause a resync.
19-02-2018 7:34 PM
According to the last GEA test, it's on a 3 dB target SNRM setting.
19-02-2018 7:41 PM
It is on 3dB default it is just that it resynched before the crosstalk from other users came in
- « Previous
- Next »
