Help of diagnosing my high error rates causing resyncs
- Help of diagnosing my high error rates causing res...
10-02-2018 11:20 PM - edited 10-02-2018 11:27 PM
Typically I am getting between 3000 and 6000 FEC per minute
The last time a GEA test was run this was the result
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0003 |
Description | No problem found, OAM test is not currently supported on this line. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 51.8 Mbps |
Upstream Speed | 10.1 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 730.7 |
Upstream Rate Assessment | Reasonable |
Downstream Rate Assessment | Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | ; 00:00 to 23:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 14 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2017-05-28T10:15:00 |
The relevant bit is this
Customer Premise |
Profile Name |
Having disconnected everything near the router and it didn't change where do I go next and would a new GEA Test provide any further information
My setup is
Incoming feed to BT Master socket with BT filtered faceplate and no internal wiring and a Billion 8800NL router connected by a screened cable
Would it be worth trying a new router (Hub 1 perhaps) to rule out the router or router power supply
Would a new GEA Test provide any further information
It just got worse so I expect a resync coming up
Re: Help of diagnosing my high error rates causing resyncs
11-02-2018 7:10 AM
Have you tried using the ordinary DSL cable that came with the modem/router? Sometimes the fancy cables don't help or even make things worse.
11-02-2018 8:28 AM
nope
will dig out a normal cable from my bits box and try that - probably tomorrow
11-02-2018 9:10 AM - edited 11-02-2018 9:11 AM
Also, the graph is over a short period, do you have one over 24 hours? And do you get the interference only between 11 and 12 at night?
11-02-2018 3:02 PM
this is more typical
and is the steady background errors even when there is virtually no internet usage
11-02-2018 3:55 PM - edited 11-02-2018 3:59 PM
Now there's a thing! Please see attached snapshot. The FEC rate on my setup was around 7000/min until I picked up the phone at about 15.37, then it shot up to nearly 30000/min. So I disconnected the phone completely and the FEC rate dropped to a max of 100/min. Then I replaced the line filter and it's dropped to next to nothing. So the line filter must be up the spout. Try replacing yours and see the effect. It's stayed very low since then.
11-02-2018 4:03 PM
Worth a try - I have a few rats tail filters knocking about as well as an old filtered faceplate
11-02-2018 4:06 PM
It's also dropped the bitswap rate to zero and the SNRM has improved.
11-02-2018 5:27 PM
I don't think FEC errors are causing the resync.
AIUI FEC errors are the kind off errors (single bit in a packet?) which the error correction algorithms in the modem simply fix on the fly. I don't think the DSLAM ever sees those as errors.
More important are the CRC errors which (I think) cause a retransmission of the packet and the errored seconds count which shows how often it happens.
My FTTC line which is clean and rock solid shows a similar set of numbers - it rises when I am streaming TV or watching BT TV on the multicast -- as I would expect, more packets = more single bit errors.
11-02-2018 5:56 PM
The increased FEC rate may well not be directly causing the resync, but it's probably an indication of something happening like increased noise/interference that does eventually cause a resync.
The amount of Internet traffic will have no relation to the FEC rate, the FEC process operates at a lower level, the rate of VDSL2 frames will be constant depending on the line rate. If your FEC rate increases while watching TV it'll be caused by something other than the level of Internet traffic.
11-02-2018 6:13 PM
Thanks - you learn every day. I assumed that VDSL2 frame traffic stopped (or went down to keep alive rates) if there was no content.
It's possible that my increase is driven by interference from the powerline adapters that carry the multicast traffic. I will replace them with a cable sometime and test that fact.
12-02-2018 4:25 PM - edited 12-02-2018 4:25 PM
filter had no effect so unless Plusnet can make a suggestion I will just live with it
12-02-2018 4:52 PM
Does unplugging all the phones including filters have any effect? Are you hard wired to the router or on WiFi from it?
12-02-2018 5:11 PM
Disconnecting the phone has no effect and two devices are hard wired and two (or more) are wireless
12-02-2018 5:23 PM - edited 12-02-2018 5:55 PM
One possibility is that the errors aren't real! Have you got another router you can try? What is the bitswap rate like?
And what kind of state is your wiring like coming in to the house and within it?
In view of the fact that you are getting disconnections as well I would guess that there is a high resistance joint on the line somewhere that's flapping about or getting wet or both.
