Having a call before the BT engineer visit
- Having a call before the BT engineer visit
Re: Having a call before the BT engineer visit
27-05-2015 1:24 PM
Quote I have spoken to our suppliers today and been advised the open exception is still being investigated by the high level escalations team. I have been informed that the order has a mismatch of data which is causing the delay. We have been asked to check back on the order on the 02/06/2015.
What's a mismatch of data ?
I'm moving in the flat on the 1st of June.
27-05-2015 6:56 PM
31-05-2015 11:57 PM
02-06-2015 6:33 PM
02-06-2015 7:28 PM
02-06-2015 7:31 PM
03-06-2015 10:33 AM
There's extra ports due to be added on the 1st of July but until then we can't get you on fibre.
If internet access is a priority it will probably be best to cancel this and go with standard broadband until then.
03-06-2015 11:14 AM
Also, if I stick to the fibre, how long would I need to wait after the increase of port numbers, will I have to wait an extra 2/3 weeks after the 1st of July to get a BT engineer to set it up in the flat as it is usually the case with Plusnet ?
03-06-2015 11:18 AM
adie:green removed phone number
03-06-2015 12:43 PM
06-07-2015 11:39 PM
can you confirm that the BT engineer will come on the 9th between 8am and 1pm ?
Last appointement was a no show, so I'd like you to confirm this one.
Thank you
07-07-2015 8:57 PM
08-07-2015 11:01 AM
08-07-2015 3:47 PM
15-07-2015 1:33 PM
You made me wait months for the upgrade of the fibre cabinet of the area, in order to have space to cable my flat,
and you finally annonced that it was ready,
you sent a BT engineer, and what happened ?
After coming on site he said that the cabinet still haven't been upgraded and there's no space for any new flat to be connected !
