Have BT switched my connection back to ordinary broadband?
- Have BT switched my connection back to ordinary br...
21-10-2015 2:59 PM
During last winter the download speed dropped from the maximum to mid twenties and over the summer it varied between 15-24 Mb depending on the weather. Speed always drops when it rains and then improves over several days back to a minimum of 15Mb. Until now!
Three weeks ago we had severe thunder storms with torrential rain. The storms lasted for several days. Since then my broadband speed has remained below 8MB and speedtest.btwholesale.com results now seem to be for ADSL broadband instead of fibre also the test no longer provides Further Diagnostic Results. These are the results from a few minutes ago:
Download speed achieved during the test was - 6.43 Mbps
For your connection, the acceptable range of speeds is 5.67 Mbps-8.11 Mbps .
Additional Information:
IP Profile for your line is - 8.11 Mbps
Upload speed achieved during the test was - 0.12Mbps
Plusnet's data transfer speed also no longer shows fibre speed estimate:
High-speed Broadband
Estimated line speed:
Current line speed:
8.1 Mb
Am I correct in thinking that my Unlimited fibre is now ordinary ADSL?
I raised a ticket last week (reference number: 112490242) but because there was some noise on the phone line it is being treated as phone fault rather than broadband. But after a week of dry weather the phone line is quiet again and will probably remain so until until we have further heavy rain.
I'd be grateful for any advice /suggestions.
Re: Have BT switched my connection back to ordinary broadband?
21-10-2015 3:05 PM
Quote Am I correct in thinking that my Unlimited fibre is now ordinary ADSL?
In short, no. Your line is still on fibre, however I can see the speeds have dropped significantly. This is probably related to the noise on the phone line or an underlying fault causing the problem.
I'm just testing the line now and will post back again shortly.
21-10-2015 3:11 PM
Currently your line is:
Downstream Speed 8.4 Mbps
Upstream Speed 0.2 Mbps
Profile Name 0.128M-10M Downstream, Retransmission High - 0.128M-3.7M Upstream, Retransmission High
Description Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report
So I'm going to push the fault through now.
21-10-2015 4:05 PM
22-10-2015 9:40 AM
22-10-2015 7:37 PM
I've just got home from work. My dad says the BT Engineer came this afternoon. He told dad that he'd traced the fault to a loose connection in the fibre cabinet: my line had been doubled up with someone else's but the connection was loose so he crimped the wires. Engineer said there's been a lot of faults in this neighbourhood recently and I should call them out immediately if speed drops again. He reset the IP profile but said it will take up to 10 days to settle.
I've just run http://speedtest.btwholesale.com/ and here's the results:
Download speed achieved during the test was - 7.8 Mbps
For your connection, the acceptable range of speeds is 31.77 Mbps-45.39 Mbps .
IP Profile for your line is - 45.39 Mbps
Upload speed achieved during the test was - 11.26Mbps
One last (probably dumb) question. Upload speed has increased significantly but download speed is still 7.8Mbps. Do I have to shutdown and restart the Openreach fibre modem and/or Plusnet router (Technicolor TG582n) to get the correct fibre download speeds?
22-10-2015 8:06 PM
Anway to your current issue, don't touch the modem just log into the router and on the left panel pick broadband connection then click the button that says disconnect the Led on the router that says internet should go red when that's done wait about 30 secs to a min and press the button again to connect, the led should then go back to green.
run the BTW test again and the speed should be as normal.
22-10-2015 8:15 PM
22-10-2015 8:31 PM
Download speed achieved during the test was - 7.75 Mbps
23-10-2015 9:11 AM
Quote from: rhinocratic
Current line speed:
8.1 Mb
23-10-2015 10:57 AM
Will it update automatically or should I raise it direct with Plusnet?
23-10-2015 11:00 AM
It should happen automatically but using Live Chat will get it done immediately
23-10-2015 1:17 PM
