Half supposed speed.
Boxcleva
I appreciate the 'up to' part of the up to 40mb service I signed up to, and i also understand the many variables that can affect the speed, but the BT engineer who installed my Fibre told (and showed me on his tester) that my line was capable of 80mb download speeds. My cabinet is 25 yards from my front door and he also told me that they was plenty of capacity in my cabinet. He also said my line was very good.So I am confused at to why I'm only getting a measly 20mb ?
Thank you
26 REPLIES 26
Oldjim
Resting Legend
Fixes: 63
Re: Half supposed speed.
What does the Current Line Speed say - see my sig for a link
Are you testing wired or wireless
Boxcleva
Quote from: Oldjim
21mb
Both, there is virtually no difference.
Oldjim
Resting Legend
Fixes: 63
OK
That explains the speed
Try the BT  speedtest - further diagnostics and report the IP profile http://speedtest.btwholesale.com/
Boxcleva
Can i ask what that will achieve ?
SpendLessTime
Fixes: 86
That test will show the maximum speed that BT Wholesale (who supply Plusnet's service) say you can get as well as the current speed from the BTW speed test.
it is a requirement of any Plusnet fault reporting to run this test.
Boxcleva
Attached is a screenshot of my results.  Sad
Oldjim
Resting Legend
Fixes: 63
Hence your problem is the Current Line Speed which is wrong - either phone or use chat to request that it be changed to match your IP profile
Boxcleva
I'm sorry, what is it I'm specifically asking for ?
Strat
Fixes: 565
You're asking for your Plusnet profile to be increased to match your BT profile.
Boxcleva
many thanks both
Boxcleva
Apparently nothing needs adjusting as it's all set correctly. And now i've got to waste a load more time filling out a support thingamy that crashed half way through.
Would someone be kind enough to link me to the fault report page please  Angry
EDIT. Found link, thank you.
MatthewWheeler
Fixes: 479
Your connection hadn't dropped since the profile had been updated.
Are you still having issues with the speed?
 Matthew Wheeler
Boxcleva
Speeds are now at a far more acceptable 35mbps thank you
Boxcleva
Same problem is back again. Speeds ranging between 5 and 20mbps download. Could some one do whatever they did last time and fix it please.
Thank you
