Half speed
benshaw627
Half speed
I have fibre unlimited up to 76mb, my line speed is 60-80mb but the line has been constantly at a speed of 33.8mb, I have just reset my router but there’s been no change, am I being throttled? I’m not happy I’m not getting the speed I’ve signed up for.
Fixes: 86
Re: Half speed
Is this a wired or wireless connection you're talking about? If wireless, do you have the same problem wired?
benshaw627
Re: Half speed
Seems to be both. I thought it was my WiFi initially but it’s Ethernet aswell, when I check the line through my plusnet account it is telling me the speed, the below is from the website, not sure how long I’ve been this slow, I had not checked for a while, used to get 75mb constant4144763D-04DD-4BB5-B098-5BD20DE0D937.jpegScreenshot
BrightonRock
Fixes: 5
Re: Half speed
I would run through the checks at https://www.plus.net/help/broadband/connection-troubleshooting/ and then report a fault at https://www.plus.net/apps/kbdfaults
It takes a bit of your time but formally makes Plusnet aware of your problem, they have look at it, and gets the problem into the queue for action.
Fixes: 187
Re: Half speed
Sorry to hear that.
Our tests are showing a external fault on the line so we'll get that raised for you.
 Matthew Wheeler
