Had to reset password and it borked the router
- Had to reset password and it borked the router
15-06-2018 6:59 PM - edited 15-06-2018 7:00 PM
I've updated the password, factory reset and also waited a good part of a day,
I've spend more money than its worth on mobile data to just have internet this past week and was expecting a plug and play router, not a plug and die.
We've called Plusnet and they said they've seen no faults
Re: Had to reset password and it borked the router
16-06-2018 9:44 AM - edited 16-06-2018 9:45 AM
I assume that you mean your account password? Check that it has been changed by logging in to your account. If this works OK then do a factory reset on the router by pushing a paperclip or similar in the hole on the back and holding the switch closed for at least 20 seconds. Leave it for a quarter of an hour and hopefully it will sort itself out. If this fails you will have to manually configure it.
16-06-2018 3:53 PM
