Had to gateway hop to restore connection
- Re: Had to gateway hop to restore connection
02-02-2015 4:23 PM
I've just had to gateway hop to restore my internet connection, all devices in the house had no connection as all web pages just timed out.. Strangely I was still able to connect via my VPN..
Message 1 of 6
(787 Views)
5 REPLIES 5
02-02-2015 6:07 PM
Hi, how many devices are you running and on which router, I'm just curious ?
Message 2 of 6
(485 Views)
02-02-2015 6:20 PM
Still the same one ?
Quote from: KevinAndrews I can confirm I've had this issue at least twice in the 2 past week, I've done a full reset of the Technicolor TG582n FTTC Router as I had manually changed via telnet to google DNS, and have now reverted back to plusnet DNS and updated the router to Firmware R10.2.5.2 but 10-15min ago just had this issue again..
Everything connected via wireless seemed to fail (2 x wii, 3x android devices) but the Desktop PC wired kept working fine.. Strangely if I edited the network settings on one of the wii's to use 8.8.8.8 8 & 8.8.4.4 (google) that wii then worked.
More strangely once I logged in to the router using the Desktop PC all sprung back in to action without actually making any changes.
Seems odd that the router DNS server would suddenly start failing..?
Message 3 of 6
(485 Views)
02-02-2015 6:24 PM
I have 19 devices, combination of WIFI and Ethernet.. I use the Technicolor TG582n (think I should invest in a better router) I also have a DG834 used as a booster for wifi connected via powerline adaptors with DHCP turned off..
Message 4 of 6
(485 Views)
02-02-2015 6:27 PM
Yeah same router as above post, although it hasn't failed to often recently..
Message 5 of 6
(485 Views)
02-02-2015 7:09 PM
I'm using 2 Raspberry Pi's running PDNSD, I'm sure plenty other options are just as good, it's worth buying a new type Raspberry and waving goodbye to the problem once and for all for £22.50. Plus you get a very powerfull tool at the same time. It's more than worth the time and effort just for the learning curve.
Message 6 of 6
(485 Views)
