Had faulty router/modem which caused DLM to kick in so now syncing lower, how to fix it?
- Had faulty router/modem which caused DLM to kick i...
- « Previous
- 1
- 2
- Next »
Re: Had faulty router/modem which caused DLM to kick in so now syncing lower, how to fix it?
26-07-2016 9:14 PM
Unfortunately, ISPs cannot reset the DLM on FTTC like they can on ADSL. If an Openreach engineer were visiting, for a broadband task, then they could reset it. Waiting for the DLM to automatically make changes that increase the speed could be weeks or months.
Have you been moved to Plusnet's new network yet? That seems to have a side effect of resetting things, but it might be a while before their new network gets to the node your connection goes through.
26-07-2016 10:05 PM
No idea, but I did find out after a bit of research that, my cabinet has changed, and it looks like this may have been what caused my old Modem/Router to become unstable. Now this could be total coincidence.
Well this sucks, so I'm basically capped at the moment by 11Mb then. Oh well I guess the only way would be to change ISP, with prices rising on Plusnet side this might be my only way it seems.
28-07-2016 9:04 AM
Just an update.
So a few moment ago my internet went down and I thought "Oh no!" but when It came backup my sync speed was higher and interleave was off. I thought awesome. But unfortunately there seems to be something wrong with my connection now.
Having some issues with YouTube and streaming apps on my shield that is connected via cable to my router and I've run a few various speed test on BT Wholesale and I'm getting high ping and speed lower than 64Mb.
Not sure what is going on here.
28-07-2016 8:47 PM
What does the BT Wholesale further diagnostic say that's what matters
also what does your Plusnet speed profile say it should be pretty much the same as the BTw one
28-07-2016 9:35 PM
Estimated line speed:There's no speed estimate currently held on your account.Current line speed:66.8 Mb
I've attached the further diagnostics page screenshot.
If anyone can make sense of it for me it would be great.
28-07-2016 9:44 PM - edited 28-07-2016 9:45 PM
Your Plusnet Connection profile is lower than it should be at 66.8 Mb your BTw Profile is at 72.24
As i said the Plusnet profile needs to match the BTw one , you can get someone on online chat to do that for you once done just Reboot the router.
29-07-2016 12:27 AM
Well my connection just went down and I'm now synced at 79987 Kbps, whooo I thought, but still only get same speed test result. So I need someone tomorrow at Plus.Net to change my profile.
29-07-2016 12:29 PM
Excellent result! You are lucky, mine never went back up on its own. It was constantly syncing at 74000 (BTW profile of 71.55), even after a month. Only a switch of ISP (BT to Plus) cleared the banding applied to my line.
29-07-2016 1:55 PM
Looks like the speed delta reports had updated the profile on our side to 77.4Mbps in the early hours of this morning, but to save you from waiting for the next delta report I've bumped that up for you
You may need to disconnect/reconnect for this to update on your side.
- « Previous
- 1
- 2
- Next »
