Had enough.
ricky65
Had enough.
This is my third year with plusnet but it seems loyalty is for suckers as my fibre speed has become constantly worse and worse to the point it now becomes unusable and I've had enough.
Even at 10pm at night it hangs around 10 mbps, during peak hours I can't even watch youtube without constant buffering, Netflix thumbs won't even load, gaming lag is terrible.
I've given it six months with no change, and before I'm asked what device I'm using it's all, pc, phone, console, roku, so please don't ask me to run a speed test with a windows pc with a ethernet cable, tried it for over six months.
Need this sorted out for good, not short term, or a refund, next stop is the ombudsman if not.
5 REPLIES 5
Fixes: 40
Re: Had enough.
Hi @ricky65, I am sorry to hear of the issues you're having.
I have tested your line today but no faults have been detected; we are seeing a sync speed of 70.5mb and a check of your VLAN shows no signs of any congestion.
I cannot see that a fault has been previously logged with us and so if this issue is also impacting your wired connections, would advise firstly having a run through our troubleshooting here and getting connected to the test socket for the time being as shown here.
If the issue then persists, please log a fault here and we'll investigate this further.
 Lauren Barry
ricky65
Re: Had enough.
I don't mean to sound to uncooperative but I have a openreach engineer living next door, throughput your end is meaningless to what I actually receive, it depends on line rate and IP profile management.
Tested through test socket, same slow speeds, please can you find out when my contract will end as by law plusnet must now inform me, I can't find it under my plusnet account but by the start date it seems to have ended already.
My communication preference has always been set to email but I have not received any mail about this, I haven't had the time to call due to long wait times etc, I don't want to leave but I will have no choice.
ricky65
Re: Had enough.
And your online chat never works.
Fixes: 40
Re: Had enough.
Thanks for getting back to me; the sync speed is indicative of the speed we are seeing getting down the line, we can't test throughput this side I'm afraid and so rely on your wired speed test results to indicate what you are seeing your end.
There are no issues with your profile (otherwise we would see a banded sync speed) and the IP profile is also correct. All checks this side indicate no issues and therefore if you have completed the troubleshooting steps would advise raising the fault with the link provided so we can progress this further for you.
I have provided your contract end date on the account here for you.
 Lauren Barry
Marksfish
Fixes: 4
Re: Had enough.
Because they have closed it!
