Had Unlimited Fibre Extra installed today and speed is low
copperpot26
Hi
Had Unlimited Fibre Extra installed today at 9.00am. The bt engineer ran some tests and everything seemed fine. He tested my speed on his handheld computer and said i was getting 53mbps down and 19 mbps up. Plusenet estimated speed is 73 mbps.
I setup my router with ease ( Asus RT-66u ) and ran some speed tests myself on bt wholesale speed test ( wired ), and the best i have got is:
Download speed : 19.45
Upload speed : 12.61
Ping lateney : 29.25
Is this normal with a new connection or do plusnet need to do something they end? The download speed doesn't what to go past 20 mbps it seems.
skycatcherx
Re: Had Unlimited Fibre Extra installed today and speed is low
I had fibre installed last friday and BT engineers line tester showed 31MB down but my speed test showed 2.5MB which was my old adsl speed. I went on chat with plusnet and the guy said he would sort out my IP profile which was still at the adsl setting - upon reboot my speed jumped to 25MB. So i would give plus net a call....btw the engineer said he had never experienced this before but I suspected that was the problem....
copperpot26
Hi
Thanks for reply
Yeah will call them now and see what they say.
dick:quote
Fixes: 163
No need to call!
Just a single disconnect/reconnect should sort it.
 Chris Parr
 Plusnet Staff
copperpot26
Ok i take it you mean the router? yes? Thanks
dick:quote
Fixes: 163
Yep, just log in to the router and disconnect/reconnect.
 Chris Parr
 Plusnet Staff
copperpot26
Thanks Chris will try that now
dick:quote
copperpot26
Still no improvement, any more help would be great thanks
Boodz85
https://portal.plus.net/my.html?action=data_transfer_speed check your plusnet profile see if it matches the 53mb that bt have set on your ip profile, i bet it doesnt Wink
Fixes: 163
Bet you it's not causing any restrictions though Wink already checked that which is why I asked for the reconnect.
 Chris Parr
 Plusnet Staff
Fixes: 163
I'm just checking the line now.
 Chris Parr
 Plusnet Staff
Fixes: 163
I can't see any issues with either your account on our side, and the line is connected at over 55Mbps at the moment.
I'm sorry to say that if it doesn't improve we'll need to look into it as a fault, if so please report it at https://faults.plus.net
 Chris Parr
 Plusnet Staff
copperpot26
Thanks for your help so far chris
Surely if there was a fault with the line the engineer would have pick it up this morning, no? He ran test on my line and found no faults
dick:quote
copperpot26
Filled in the report a fault and answered all the questions. Says i will hear back within 24hrs.
Ran a few more speed tests and the download always comes back at around 20mbps.
Upload has improved, getting around 17/18mbps most times.
