HH5 new firmware
- Re: HH5 new firmware
HH5 new firmware
11-01-2015 11:08 AM
Software version 4.7.5.1.83.8.204 (Type A) Last updated 10/01/15
05:30:54, 11 Jan. (518434.310000) The system is going DOWN for reboot.
06:31:47, 11 Jan. ( 65.180000) System up, firmware version: 4.7.5.1.83.8.204 (Type A)
06:31:28, 11 Jan. ( 45.650000) System start TR069
why is it down for an hour?
what does it improve
11-01-2015 11:30 AM
11-01-2015 2:14 PM
What are you NTP settings on the HH5?
15-01-2015 7:46 PM
the NTP is once everyday
not off to a good start though it changed gateways another 4 times on the 11/01/15
and speed has dropped down to 25mb from 38mb
http://www.thinkbroadband.com/speedtest/button/142135016329661349521.png
but also noticed the noise has double on download
3. Firmware version:
4. Board version:
BT Hub 5A
5. DSL uptime: 4 days, 03:19:10
6. Data rate: 4489 / 26218
7. Maximum data rate:4586 / 42297
8. Noise margin: 6.2 / 12.1
9. Line attenuation: 32.5 / 22.2
10. Signal attenuation: 32.1 / 20.9
11. Data sent/received:1.0 GB / 37.1 GB
think i'll reboot it tomorrow and see what happens
16-01-2015 10:17 AM
changed gateway 16/01/15 05:57 pcl-ag02
http://www.speedtest.net/result/4063578213.png
http://www.thinkbroadband.com/speedtest/button/142140299332915166860.png
4. Board version:
BT Hub 5A
5. DSL uptime: 0 days, 04:10:24
6. Data rate: 4157 / 37573
7. Maximum data rate: 4211 / 43510
8. Noise margin: 6.1 / 6.0
9. Line attenuation: 32.5 / 23.4
10. Signal attenuation: 31.9 / 20.8
11. Data sent/received: 1.1 GB / 37.4 GB
23-02-2015 1:02 PM
then it changed gateways yesterday to pcl bng 04 and my speed dropped 8 mb
used to be 38 then awhile back dropped to 34 now down to 26
http://www.speedtest.net/result/4113435877.png ; 03/02/15
http://www.speedtest.net/result/4151845912.png ; 18/02/15
http://www.speedtest.net/result/4164541958.png ; today
is there a problem with this gateway
24-02-2015 2:03 PM
did a disconect and switched off router and speed still down so did bt test
Download Speed 26.41 Mbps
0 Mbps 36.68 Mbps Max Achievable Speed
Download speedachieved during the test was - 26.41 Mbps
For your connection, the acceptable range of speedsis 25.68 Mbps-36.68 Mbps .
Additional Information:
IP Profile for your line is - 36.68 Mbps
Upload Speed
3.75 Mbps
0 Mbps
20 Mbps
Upload speed achieved during the test was - 3.75Mbps
so where has my speed gone?
24-02-2015 6:22 PM
25-02-2015 7:14 AM
25-02-2015 2:20 PM
http://www.speedtest.net/results.php?sh=b957cee15ba6369a961555c4f8ec22e8&ria=0
web pages are not loading as fast as they were and changing gateways every day after a run of 16 days without change.
25-02-2015 7:20 PM
Quote from: ricke17 Other than not having my HH5 reboot or lose connection - how do I know if this configeration deployment has been done on my router?
Look in the Event Log under TR069 to see if you have......
(345639.190000) CWMP: Download file, FileType=4, FileName=5A-FixMajorUpgrade-4.1.tar.gz.aes.rsa.signed, Username=, CommandKey=1951971283
Mine came on the 22nd Feb.
25-02-2015 7:23 PM
26-02-2015 2:18 PM
found that file and it was done on the 23rd feb, so has that mucked up my speed
does the router need a factory reset?
just had another look at TR096 file and it has been downloaded :-
23:15:09, 20 Feb. (1512234.370000) CWMP: Download file, FileType=4, FileName=5A-FixMajorUpgrade-4.1.tar.gz.aes.rsa.signed, Username=, CommandKey=1949128173
23:15:09, 22 Feb. (1685030.150000) CWMP: Download file, FileType=4, FileName=5A-FixMajorUpgrade-4.1.tar.gz.aes.rsa.signed, Username=, CommandKey=1953266071
23:15:07, 23 Feb. (1771426.210000) CWMP: Download file, FileType=4, FileName=5A-FixMajorUpgrade-4.1.tar.gz.aes.rsa.signed, Username=, CommandKey=1954354774
12:32:31, 25 Feb. (83721.970000) CWMP: Download file, FileType=4, FileName=5A-FixMajorUpgrade-4.1.tar.gz.aes.rsa.signed, Username=, CommandKey=1955625410
23:15:07, 25 Feb. (122278.080000) CWMP: Download file, FileType=4, FileName=5A-FixMajorUpgrade-4.1.tar.gz.aes.rsa.signed, Username=, CommandKey=1956043151
after each one it says (122278.330000) CWMP: session completed successfully
26-02-2015 6:50 PM
Certainly worth trying a Factory Reset, Although I haven't done so on mine.
I've got an Uptime of 8 days so far, that's good for my HH5. It normally reboots every
2 days or more. Hopefully the update has fixed this.
27-02-2015 4:43 PM
speed has not gone back up to what it was
