Good RJ11 telephone cable?
- Good RJ11 telephone cable?
24-07-2015 9:37 AM
Cheers.
Re: Good RJ11 telephone cable?
24-07-2015 9:53 AM
Note that an extension from the phone part of the filtered faceplate wouldn't have that problem
24-07-2015 9:59 AM
Does it improve the connection? I can't be sure but for the cost, it is worth a try.
24-07-2015 9:59 AM
24-07-2015 10:01 AM
24-07-2015 10:03 AM
24-07-2015 10:19 AM
24-07-2015 10:54 AM
http://www.tandyonline.co.uk/high-speed-rj11-dsl-cable-5m.html
24-07-2015 11:46 AM
24-07-2015 12:04 PM
Quote from: artfulbodger It's the phone (rj11) to BT socket (bt431a) that I'm after.
I don't think 1m of filtered cable to the phone is going to affect your broadband? What aren't you happy with? If you unplug the phone cable from the master socket what improves?
24-07-2015 12:51 PM
Before everyone jumps on the bandwagon and says "if it ain't broken, don't fix ... etc etc", but I was just thinking how bad DECT phones can be near a mastersocket/FTTC setup?
Cheers!
24-07-2015 12:56 PM
Just saw your reply about a possible REIN issue. Do you have the means to monitor the errors on your line (for example, an unlocked modem that you can use to monitor line stats)? That would allow you to monitor error rates (FEC is useful to monitor) and then you can change things about and see what has a positive effect.
I had a similar issue with noise from power line networking adapters. I had no idea there was even a problem until I started monitoring line stats. Once I had the stats, I could start to switch things off, move wiring etc, to see what reduced the FEC error rate on the line.
Might be worth considering. What model of modem do you have?
24-07-2015 1:23 PM
Might change the faceplate to a Mk3, can't harm things I guess.
24-07-2015 1:25 PM
Quote from: artfulbodger Thanks Jason. The twisted pair DSL is what I've got already between the modem and master socket. It's the phone (rj11) to BT socket (bt431a) that I'm after. Unless I'm looking for something that doesn't exist?
http://www.amazon.co.uk/BT431A-RJ11-telecom-test-adaptor/dp/B000Q8L33E
How about this, then use the twisted pair JR11 cable.
24-07-2015 1:28 PM
Cheers!
