Getting very slow speeds after moving to Plusnet
zephyrmop
We moved house recently and moved to plusnet which went live on Fri 5th May. Initially we were getting speeds on 2mbs that evening, and since then it's increased to almost 7mbs, specifically 6.88mbs seems to be the limit it can hit.
I'm aware that it can take 10 days to receive full speeds but I would have hoped they would have increased by alot more since we should apparently be getting almost 70mbs.
Using the BTwholesale speed test we can get: 6.96mbs and 80.13 ping.
Our line speed is:
Estimated line speed:68Mb (This may vary between 50.8Mb and 68.2Mb) - Checked on 2017-04-20 21:42:31
Current line speed:7.15 Mb
We have checked with wireless and ethernet, and on mobile phones as well.
If there's any other info I can give then let me know, otherwise I'm hoping someone can offer some assistance to why our speeds are so slow
Thanks in advance
18 REPLIES 18
rongtw
Fixes: 12
Re: Getting very slow speeds after moving to Plusnet
Hi 😀
Firstly there is no 10 day training period for FTTC connections .48 hours should be enough for DLM to work
I hope you are testing wired and not WiFi ?
And which router are you using , all this will help
Strat
Fixes: 565
Looks like you may need a PN rep to nudge your profile.
zephyrmop
Yep, I've tested with both wired and wireless and am getting throttled at about 7mbs. Also my router is the supplied one with fibre called the plusnet hub one. I can't find a model name/number for it.
Just a case of waiting for a plusnet staff member to see my post I guess?
RealAleMadrid
Aspiring Hero
Fixes: 59
Call customer service, they can fix it. I had to do this when I was upgraded to FTTC. This forum is not a quick support channel.
TonyMC
Hi Dan, Could you tell me your account user name & I will have a look into this for you - Tony
Strat
Fixes: 565
You can Private Message TonyMC here
TonyMC
Hi, I still don't have your account user name, can you send it so that I can help you.
Champnet
Aspiring Hero
Fixes: 12
I wonder if there's a confusion between mbps and Mbps ?
mbps is mentioned 5 times and Mbps is mentioned 4 times.
@zephyrmop Does the connection seem slow ?Huh
TonyMC
Hi, Doesn't matter how you write it both mean Mega Bits Per Second
Browni
Aspiring Hero
Fixes: 60
Strictly speaking a prefix of 'm' is a multiplier of 10^-3 (milli-) and 'M' is a multiplier of 10^6 (Mega-) however in the context of this thread it can be safely assumed it is the latter.
In the case of bits and Bytes however it is sometimes not clear which unit is being referred to.
Champnet
Aspiring Hero
Fixes: 12
Agreed, but if you take some of the  low numbers for Mb & mb and treat them as MB then the converted comparisons are very close. Hence the question "Does the connection seem slow ?"
Probably got this completely wrong so I'm off to sit in the sun.......
Fixes: 1,600
Hi there @zephyrmop
I am sorry to hear you are having speed issues.
I've found the problem. It's not a profiling issue. The agent that placed the order with our suppliers provisioned the service on ADSL broadband instead of fibre broadband. Sad
I am in the process of modifying the service now, but this will take a minimum lead time of 5 working days I'm afraid. I will be passing on internal feed back to my manager in regards to this.
I've created this ticket on your account with more information.
Once again, I sincerely apologise for this.
rongtw
Fixes: 12
@Gandalf Oh Dear Embarrassed  not good , agent needs a bit of retraining
Fixes: 1,600
Yeah, I've passed on feedback.
