Getting very low upload speed
- Re: Getting very low upload speed
03-08-2019 6:39 PM
Have unlited fibre extra only gettintg 0.72 upload speed should be getting at least getting 10mb plus.
Message 1 of 2
(341 Views)
1 REPLY 1
04-08-2019 7:51 PM
Hi @Kulj1982, I'm sorry for the issues.
I've tested your line and can certainly see that you're upload is running lower than estimated at 1.1mb (you should be getting about 12-18mb) but the cause of this hasn't been picked up.
I'd advise running through our troubleshooting here and getting your router connected into the test socket and raising a fault here if the issue persists. If you let us know once you've done this we can pick it up and investigate this further for you.
Message 2 of 2
(302 Views)
