Gea test
FIXEDTopic Options
- Gea test
26-07-2018 9:00 PM
Can i have a GEA line test
3. Firmware version: | Software version 4.7.5.1.83.8.237.2.2 Last updated 13/08/17 |
4. Board version: | Plusnet Hub One |
5. DSL uptime: | 3 days, 21:01:46 |
6. Data rate: | 6530 / 25963 |
7. Maximum data rate: | 6500 / 29510 |
8. Noise margin: | 6.0 / 6.8 |
9. Line attenuation: | 40.3 / 27.4 |
10. Signal attenuation: | 26.9 / 24.8 |
Fixed! Go to the fix.
Message 1 of 2
(488 Views)
1 REPLY 1
27-07-2018 10:36 AM - edited 27-07-2018 10:37 AM
Hi @petergilf,
Thank you for getting in touch. I've carried out a GEA test on your line and the result is as follows:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 26.0 Mbps | ||||
Upstream Speed | 6.5 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 1136.6 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | From 01:30 to 15:15 | ||||
Interference Location | Customer Premise | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2018-07-14T10:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 25.1 Mbps | 25.9 Mbps | 25.3 Mbps |
Up Stream Line Rate | 6.5 Mbps | 6.6 Mbps | 6.5 Mbps |
Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-07-27T10:01:52.079+01:00 | 2018-07-27T10:16:52.079+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
This test isn't picking up any issues from this side, are you experiencing any problems with your connection the moment?
