Gea test
williamsben16
Gea test
can you test both my lines please other one is [Removed]
Moderator's note by Mike (Mav): Personal information removed from a public forum (to an area that staff can see).
Fixes: 385
Re: Gea test
Hi there.
Here's the one for the username you provided us in your original post:
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 29.4 Mbps
Upstream Speed 7.8 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Not Run - Unable to run
Bridge Tap Detected
Cross Talk Detected
Estimated Line Length In Metres 1045.8
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Service Impact Retrains Observed
Interference Duration Longest Occurrence From 04:00 to 04:15
Interference Location Unknown
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
And this one is for the username in your forum profile:
Test Outcome Pass
Sync Status In Sync
Downstream Speed 28.2 Mbps
Upstream Speed 6.8 Mbps
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 964.7
Upstream Rate Assessment Good
Technology VDSL
Profile Name 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
williamsben16
Re: Gea test
are the stats on first line ok
Fixes: 180
Re: Gea test
Hi @williamsben16,
The first line (UN provided in Original Post) seem in line with the estimates for the line which are 25Mbps-37Mbps for download and 5Mbps-7.4Mbps for upload.
However, looking at the second test (For the username on your forum profile) it looks like it's provisioned on 80/20, so it may be worth considering dropping down from the Extra package to just Unlimited Fibre (Which offers speeds up to 38Mbps download and up to 9.5Mbps upload, and is provisioned on 40/10) to save some money as the estimates for that line are only 30Mbps-43Mbps for download and 5.3Mbps-7.8Mbps upload.
I'd also advise going through our troubleshooting guide for this line as the test is indicating the speeds are below the estimate for the line.
Should the speeds not bump back up within the estimates after troubleshooting, please report a fault over at https://faults.plus.net so we can investigate this further.
I hope this helps.
 Harry Beesley
