Gateway checker ??
rongtw
Fixes: 12
Gateway checker ??
is the Gateway checker down Huh  tried several time in last hour   FF and Chrome ,, connection times out  ?Huh
Fixes: 31
Re: Gateway checker ??
Its not working for me either.
Browni
Aspiring Hero
Fixes: 45
Timing out for me as well.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
rongtw
Fixes: 12
still not working at 16.22 ?
Any staff available to check and investigate ?
Terranova667
Seems to be working now
You are currently connected to gateway pcn-ir01.
This is located in Colindale Point of Presence.
Browni
Aspiring Hero
Fixes: 45
Working here as well now.
You are currently connected to gateway pcn-bng03.
Fixes: 31
Its back for me too:
You are currently connected to gateway psb-bng01.
This is located in Southbank Point of Presence
rongtw
Fixes: 12
yes its working now Thumbs Up
Fixes: 86
There was a problem with the platform where it's hosted. Came back after a server restart.
