Gateway checker
rongtw
Fixes: 12
Gateway checker
Is it borked Huh  or is it just because PN setting up new network ?
Which gateway
You are currently connected to gateway pcl-ag02.
This is located in City Lifeline House.
but from tracert via CMD shows  PTW - BNG 02
11 REPLIES 11
etdsaunders
Fixes: 7
Re: Gateway checker
Works fine here  Smiley
You are currently connected to gateway ptn-bng02.
which is also the same via tracert  Cool maybe a ptw-bng issue?
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs_Up
spraxyt
Resting Legend
Fixes: 75
Re: Gateway checker
I am not aware of any reason why the result from the gateway checker should be incorrect. However when reusing IPs during network rearrangement, changing the reverse DNS entries has not been a high priority so either could be wrong.
If you are happy to PM your IP address to me I'll run some diagnostic checks.
David
tfc
Re: Gateway checker
Again . . . .
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Update topic (which is now locked!) in the Community Announcements forum will help us to diagnose the problem.
  • core1-hu0-9-0-1.southbank.ukcore.bt.net (195.99.127.2) 4.482 ms
  • 195.99.125.139 (195.99.125.139) 4.417 ms
Does this have anything to do with the fact that my ISP is now shown as "Guidant - Hong Kong" when I look using whois.arin.net via Fing, or IPNetInfo.
NetRange: 209.93.180.128 - 209.93.180.255
CIDR: 209.93.180.128/25
NetName: GUIDANT-HKG1
NetHandle: NET-209-93-180-128-1
Parent: PLUSNET5 (NET-209-93-0-0-1)
NetType: Reassigned
OriginAS:
Customer: GUIDANT - HONG KONG (C01086988)
RegDate: 1998-06-05
Updated: 2005-05-09
Ref: https://whois.arin.net/rest/net/NET-209-93-180-128-1
CustName: GUIDANT - HONG KONG
Address: tungwai commercial bldg, 109-112 gloucester, suite 2401
Address: Wangchai,
City:
StateProv:
PostalCode:
Country: HK
RegDate: 1998-06-05
Updated: 2011-03-19
Ref: https://whois.arin.net/rest/customer/C01086988
My address is in the 209.93.180 range of addresses (within the range allocated to Guidant Hong Kong).
Does this mean our details and data are being handled in Hong Kong, (with or without Chinese government 'assistance'? Or are PlusNet moving into supplying services to Hong Kong?
It doesn't quite ring true with the Plusnet Yorkshire adverts.
andytay
Re: Gateway checker
Posting the following information as a reply to the Gateway Checker Update topic in the Community Announcements forum will help us to diagnose the problem.
  • 195.99.126.139 (195.99.126.139) 2.957 ms
  • lts3.bt622-12.plus.net (212.159.1.195) 4.611 ms
  • gi7-1-161.pcl-gw01.plus.net (84.93.255.81) 3.259 ms
I'm confused?
So what is my problem and how can i fix it?
Chris
Legend
Fixes: 169
Re: Gateway checker
Are you having any problems with your connection?
andytay
Re: Gateway checker
just resolver issues and slow loading web pages
bobpullen
Fixes: 316
Re: Gateway checker
It means neither. The range your IP is assigned from has been used by others prior to us acquiring it. Because this is an ARIN address, it's likely it will stay registered to an entity outside of the UK, however the popular geo-location databases should all have been updated to show UK as the location of use.
I've a suspicion the problem you're seeing is related to this.
I'm confused?
Looks like 84.93.255.81 has the wrong rDNS assignment. That will also need fixing by us. The gateway is ptw-bng02.
spraxyt
Resting Legend
Fixes: 75
Re: Gateway checker
I'm confused?
@bobpullen As a short-term measure until the rDNS entry is updated I've corrected that by applying a temporary fix to the gateway checker.
Also I've assumed that 195.99.125.139 (from the earlier report) which lacks rDNS is psb-ir01. Is that correct?
David
bobpullen
Fixes: 316
Re: Gateway checker
Not sure. If @tfc can post an outbound traceroute then we should be able to confirm?
tfc
Re: Gateway checker
Thank you everyone.
Here is the tracert as requested.
Tracing route to e10088.dspb.akamaiedge.net [104.82.197.203]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  10.10.74.1
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4    19 ms    18 ms    19 ms  be3-3104.psb-ir01.plus.net [195.166.143.136]
  5    19 ms    18 ms    19 ms  core1-BE1.southbank.ukcore.bt.net [195.99.125.130]
  6    20 ms    18 ms    18 ms  core3-hu0-1-0-0.faraday.ukcore.bt.net [195.99.127.32]
  7    18 ms    18 ms    21 ms  peer1-et-3-3-0.faraday.ukcore.bt.net [62.6.201.165]
  8    19 ms    19 ms    18 ms  195.99.126.19
  9    18 ms    18 ms    17 ms  a104-82-197-203.deploy.static.akamaitechnologies.com [104.82.197.203]
Trace complete.
My gateway is now reported as:-
You are currently connected to gateway psb-ir01.
This is located in Southbank Point of Presence.
IPNetInfo now tells me :-
NetRange: 209.93.0.0 - 209.93.255.255
CIDR: 209.93.0.0/16
NetName: PLUSNET5
NetHandle: NET-209-93-0-0-1
Parent: NET209 (NET-209-0-0-0-0)
NetType: Direct Allocation
OriginAS: AS6871
Organization: INFONET Services Corporation (INFO)
RegDate: 1997-06-04
Updated: 2016-01-19
Comment: ADDRESSES WITHIN THIS BLOCK ARE NON-PORTABLE
Ref: https://whois.arin.net/rest/net/NET-209-93-0-0-1
OrgName: INFONET Services Corporation
OrgId: INFO
Address: 2160 East Grand Avenue
City: El Segundo
StateProv: CA
PostalCode: 90245-1022
Country: US
RegDate:
Updated: 2011-11-30
Ref: https://whois.arin.net/rest/org/INFO
Fing still tells me Guidant - Hong Kong, with Location of Hong Kong.
spraxyt
Resting Legend
Fixes: 75
Re: Gateway checker
Thanks @tfc
The outbound trace confirms my gateway assumption for your IP (psb-ir01) is correct. The checker tool now reports that. Smiley
The IPNetInfo record for the range seems correct. The Fing information is (at best) well out of date.
David
