Gateway check.I've lost my tab.please help!!
Fixes: 4
Stupid me, I've forgotten how to check my gateway.  Embarrassed
Please someone put me out of my misery & show me the link.
Thanks,
Nick
Fixes: 10
Re: Gateway check.I've lost my tab.please help!!
http://usertools.plus.net/@gateway
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 4
Thanks spoonw, I'm blushing!!! Embarrassed
SpendLessTime
Aspiring Hero
Fixes: 81
This version gives you the IP address of the gateway which you may find more useful http://users.plus.net/@gateway_custom?debug-ip=yes
Fixes: 4
Thanks George, but that info is way above my knowledge base!! Huh
SpendLessTime
Aspiring Hero
Fixes: 81
Well every gateway has multiple physical machines each with their own IP address so knowing which machine by the IP address can help highlight performance issues.
You only need to note the IP address with the gateway name in it, it's normally on the 2nd to last line given. Worth reporting it if you are experiencing a slow down as has been done in the Further Capacity Issues thread.
Fixes: 4
Ah, now I understand. Thanks George, my knowledge base is expanding daily, it's quite painful at my advanced years!! Shocked
