Gateway Check Issues.
Alucidnation
Just checking my gateway to see if i had been booted and i get the following...
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Update topic in the Community Announcements forum will help us to diagnose the problem.
  • core1-hu0-9-0-1.southbank.ukcore.bt.net (195.99.127.2) 5.010 ms
  • be10.psb-ir01.plusnet.bt.net (195.99.125.131) 5.783 ms
I tried to report this in the dedicated thread but its been locked.
Anyone know why i am getting this message?
Fixes: 5
Re: Gateway Check Issues.
I would guess you've been moved to Plusnets new network.
https://community.plus.net/t5/Plusnet-Feedback/Plusnet-New-Network/td-p/1300536
Luzern
Seasoned Pro
What % of users are now over? I don't think I am and can't recall how to tell anyhow! ;(
Fixes: 46
Thanks for reporting this. You've been moved to the new network. Your gateway will be shown as the Internet Router psb-ir01. Changes to the gateway checker to pick this up will be going live in a few minutes.
Sorry about the reporting problem which is a side effect of posting rules on the new Community forum. I'll contact the Mods to find a solution to this.
David
Fixes: 46
@Alucidnation
The Gateway Checker update is now live. Does it show your gateway as psb-ir01 in Southbank Point of Presence now?
David
Alucidnation
Yes indeed all sorted thanks!
Can you tell what date we were swapped over?
rongtw
Fixes: 12
Yes it has been some time since PN posted a update
Fixes: 46
Sorry I don't have access to that information.
David
Alucidnation
OK thanks anyway.
Connection so far seems a bit more stable, connection speed the same.
Ping times have dropped considerably to around 10ms from nearly 20ms.
Not sure if I can, or even need to gateway hop, as I haven't had any reason to. Yet.
Alucidnation
Just checking my gateway again as things have gone a bit odd and i now get....
Custom diagnostic check on IP 147.147.192.215
Array
    [1] =>  7  core2-hu0-18-0-0.southbank.ukcore.bt.net (62.172.103.24)  4.533 ms
  • core2-hu0-18-0-0.southbank.ukcore.bt.net (62.172.103.24) 4.533 ms
Fixes: 46
@Alucidnation Thanks for the report. What did you mean by "things have gone a bit odd"? General access to websites on the Internet or just the gateway checker? Huh
The 147.147.0.0/16 IP range you are on now is another new one though whois shows it was reassigned from ARIN (USA) to RIPE (Europe) so hopefully geolocation will be less troublesome.
The result you got from the checker implies the Internet Router that trace passed through does not respond to ICMP pings. That will need to be looked at by Plusnet.
A standard 3-sample UDP trace from the command line on the Usertools box shows a psb-ir01 gateway twice and no response once. Repeating this with ICMP pings gives no response 3 times.
Whilst ICMP echo behaviour needs to be looked at none of this implies routing should be affected. Is your feeling that it is?
David
Alucidnation
At meaning odd, I meant that general browsing 'snappiness' isn't there like it was and i also have an internet radio that started to buffer again (like it did before when i was on the old network) which is why i did a gateway check.
As for the command line reference, that is how my browser pasted it so i didn't perform any technical checks as i dont know how..
Still noticing things run a little slower in the evenings as well.
Fixes: 46
@Alucidnation Thanks for the explanations.
Performance issues are something Plusnet need to investigate - @bobpullen?
Sorry, my references to 'command line' testing related to checks I'd done which are not available through browsers. So additional information beyond that you could gather and report. Smiley
For information the 3-sample UDP trace gave
 7  core1-hu0-9-0-1.southbank.ukcore.bt.net
              (195.99.127.2)  5.747 ms
              (62.172.103.24)  3.589 ms  3.753 ms
 8  195.99.125.139 (195.99.125.139)  3.645 ms
               (195.99.125.131)  4.710 ms
It is the router shown by '*' in hop 8 which didn't respond to the traceroute probe and which Plusnet need to follow up.
David
Fixes: 70
There's no reason your performance should be suffering on the new network, if anything latency should be better. I can see you've since disconnected/reconnected and the gateway checker now looks to be working. If it is, and you're still experiencing performance problems, then the two things are unrelated.
I've asked our engineers to take a look. It's definitely not affecting all of the IR's.
Plusnet Products Team
Alucidnation
Ok thanks,
However, i have not disconnected/reconnected since my post on Sunday, unless you mean something else?
This is my latest gateway check..
Array
    [1] =>  7  core2-hu0-18-0-0.southbank.ukcore.bt.net (62.172.103.24)  4.988 ms
  • core2-hu0-18-0-0.southbank.ukcore.bt.net (62.172.103.24) 4.988 ms
