Gateway Affects Speed
akashi
I have noticed I am getting slower speeds than my usual 72/73Mbps download speed.
My BT profile appears to be okay. However, my download speeds range from 68-70Mbps and this varies depends on which gateway I connect to.
So far it only appears to connect to psb-bng01, psb-bng02 and psb-bng03. I have done many WAN reconnects via the router and only connects to these three.
Is there any ways for force connect to a different gateway to get the old speed back?
Line Mode: G.993.2 (VDSL2) — Annex B — Profile 17a
Status & Uptime: UP — 22m 9s — Resyncs: 1
Line State: showtime_tc_sync [0x801]
Power Mode: L0 - Synchronized
Downstream — Upstream
Attainable Line Speed: 75.817 Mb/s — 27.217 Mb/s
Actual Line Speed: 77.118 Mb/s — 20.000 Mb/s
Trellis: D: ON — U: ON
Bitswap: D: ON — U: OFF
G.INP: D: Not Enabled — U: Not Enabled
Virtual Noise Support: D: Not Supported — U: Not Supported
Interleave Depth: 1 — 1
Interleave Block: 255 — 255
Interleave Delay: 0.0 ms — 0.0 ms
INP: 0.0 — 0.0
NFEC: 255 — 255
RFEC: 16 — 16
LSYMB: 20664 — 5410
LPATH: 0 — 0
Line Attenuation: 15.8 dB / 17.2 dB
Noise Margin/SNR: 5.6 dB / 9.6 dB
Transmit Power: 5.2 dBm / 5.0 dBm
Errors Since Line Up
FECS: 713 — 12462
ES: 10 — 1215
SES: 0 — 0
LOSS: 0 — 60
UAS: 40 — 40
HEC: 0 — 0
CRC_P: 20 — 0
CRCP_P: 0 — 0
Errors in 15 Minutes
Code Violations: 0 — 0
FECS: 9 — 1
Errors in 1 Day
Code Violations: 26 — 0
FECS: 704 — 4
5 REPLIES 5
adamwalker
Fixes: 221
Re: Gateway Affects Speed
That's unusual as we'd not expect you to see such a difference. Is this still an issue? if so some results of traceroutes to each gateway would help us to start looking at that in more detail.
There isn't a way of forcing your connection onto a particular gateway, so if that's something you wanted to do it's just a case of rebooting until it changes. As a word of caution and in case you're unaware I'd avoid doing that excessively as that can cause other problems.
 Adam Walker
akashi
Thanks for your input.
I have acquired a new BT Openreach modem by ECI and have synced at a slightly higher speed of 75.94Mbps.
Speed tests are still around 68/69Mbps and no higher Sad
I am wondering if I will ever see the speed of 72Mbps again
I noticed some of Plusnet's gateway start with PCN and others PSB. Not sure if one is meant to be faster than the other?
akashi
I have noticed the speed on the Plusnet site mentions 72.8Mbps whereas the BT IP Profile is 75.94Mbps.
 - https://portal.plus.net/my.html?action=data_transfer_speed
Can this be the reason why I am not reaching the possible maximum bandwidth?
Thanks.
akashi
I called support this morning and the Plusnet speed profile was updated to match the BT IP profile.
I am now getting 72Mbps like before.
Fixes: 1,600
Apologies for the delayed response on here
Happy to hear your speed is back up
Let us know if there's anything else we can assist with
