Gandalf - Help Please - Sudden Speed drop as of 1st Jan 2019
daveg6hni
Anoush Hi,
Before I go through the pain of opening a fault ticket, can you or someone at PlusNet please just check my line
After months of intermittent faults last year BT finally found a problem and since 25th July 18 my download speed has been a steady 37.1 Mbps or thereabouts, but yesterday it suddenly dropped to a low of 20.8 Mbps and is currently only 26.9 Mbps
Up until 31st Dec I had...
Attainable speed was 44500 Kbps
Sync Speed and throughput was 40000 kbps
SNR was >11 dB
However, since 1st Jan 2019 it is much much lower, this cannot just be a coincidence, something major has changed either at the exchange or at PlusNet ?
Please see attached Sam Knows graph and router stats below, I will see if I can find my router stats from before it fell off the cliff.
I have tried restarting the router, but after I post this I will turn it off for 15 mins just to see if that does anything
Regards, Dave.
Receive Direction Send Direction
Max. DSLAM throughput kbit/s 40000 10000
Min. DSLAM throughput kbit/s 128 128
Attainable throughput kbit/s 39239 6678
Current throughput kbit/s 31224 6678
Seamless rate adaptation   off off
Latency   fast fast
Impulse Noise Protection (INP)   32 0
G.INP   on off
Signal-to-noise ratio dB 11 6
Bitswap   on off
Line attenuation dB 25 27
approximate line length m 785
Profile 17a
G.Vector   off off
Carrier record   A43 A43
Error Counter
  Seconds With Not Remediable Errors (CRC)
  Errors (ES) Many
Errors (SES)
per
Minute
Last
15 Minutes
FRITZ!Box 3 0 0 0
Central exchange 275 0 0.16
11
9 REPLIES 9
adamwalker
Fixes: 221
Re: Gandalf - Help Please - Sudden Speed drop as of 1st Jan 2019
Hi Dave, I've just had a look into this and have run diagnostics which don't point towards any obvious issues.
Assuming the slow speeds have been noticed over a wired rather than wireless connection reporting a fault would be the way to go.
 Adam Walker
daveg6hni
Adam Hi and thanks for the quick reply.
I have just tried the old turn it of and on again, albeit with a 15min off time and it has come back at normal speed Smiley
I will monitor it for a few days though just to make sure, but that appears to have fixed it... Smiley
Post power down stats below
Regards, Dave.
Negotiated Connection Properties
Attainable throughput kbit/s 42565 6615
Current throughput kbit/s 39936 6615
Latency   fast fast
Impulse Noise Protection (INP)   43 0
G.INP   on off
Signal-to-noise ratio dB 7 6
Bitswap   on off
approximate line length m 820
Profile 17a
G.Vector   off off
Error Counter
  Errors (ES) Many
Errors (SES)
per
Minute
Last
15 Minutes
FRITZ!Box 0 0 0 0
Central exchange 0 0 0 0
BD
Fixes: 86
Hi @daveg6hni, thanks for getting back to us and I'm glad to hear your speeds look to have returned to normal. By all means if you do notice any issues with the connection moving forwards please do let us know and we'll happily to look into this further for you.
daveg6hni
I may have spoken too soon...My best Sam Knows speed check since the reboot is only 29.5 Mbps and the last one at 3 am was only 26.6 Mbps Sad
The router is still syncing as expected, it is just the download speed that is still low ?
I will try a few manual speed checks when I get home tonight, but the last time I had the same issues it all started at Midnight on 1st April 17 and finished at Midnight on the last day of June 17 and this latest issue has started at Midnight on 1st Jan 19, which is just too much of a coincidence and I suspect outside interference like a physical or system change somewhere Huh
And when I say it finished, I really mean it just became stable again, albeit at the slower 32 Mbps, not the 35 Mbps I was getting before April and it was not until the middle of 2018 that BT finally found a fault and my speed increased to 37 Mbps,.where it has been ever since, or until 1st Jan 19 that is.
Attainable throughput kbit/s 43122 6615
Latency   fast fast
G.INP   on off
Bitswap   on on
Profile 17a
G.Vector   off off
Error Counter
  Errors (ES) Many
Errors (SES)
per
Minute
Last
15 Minutes
FRITZ!Box 0 0 0 0
Central exchange 68 0 0.1 1
OskarPapa
Fixes: 65
Hi @daveg6hni, thanks for your post.
On checking the line components that we're able to check, we aren't detecting any sort of issue with the service and on looking at the table you've provided the throughput does seem to be OK.
There are a few errors exchange side in what you're seeing but on running a GEA test (see below) we're not detecting the same errors (aside from the 1 ingress violation):
GEA Test Detail
Circuit ID REDACTED Service ID REDACTED
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 39.9 Mbps
Upstream Speed 6.6 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 1008.0
Upstream Rate Assessment Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Interference Observed In Days 14
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2018-12-21T11:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 31.2 Mbps 39.9 Mbps 38.7 Mbps
Up Stream Line Rate 6.6 Mbps 6.6 Mbps 6.6 Mbps
Up Time 0.0 Sec 900.0 Sec 898.5 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-01-03T10:51:31Z 2019-01-03T11:06:31Z
Ingress Code Violation 1 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
We are seeing a bit of interference but we're not able to test your phone line and so would recommend getting your phone provider to run a copper line test, to rule out any problems that end.
Please let us know how you get on.
daveg6hni
Owen, thanks for that info,
I have just checked my Sam Knows box again and the test it did at 9:00 am was OK, it was back up to 37.1 Mbps, so I'm fearing it might be the dreaded interference issue is back that I had in 2017 which caused my speeds to fluctuate between 8 and 28 Mbps between April and June.
I will continue to monitor and I will keep my fingers crossed that it is not back.
Fixes: 1,600
Thanks for the update Dave.
Let us know how your monitoring goes.
daveg6hni
Well my router has remained synced at 40000 Kbps but the Sam Knows download tests are still a bit erratic, see graph. It is not as stable as it was before 1st Jan, but I will continue to monitor it as the CRC errors still seem a bit high at 0.19 per min, I think it used to be about 0.01 per min, not sure at what point BT's DLM kicks in ?
Attainable throughput kbit/s 42745 6615
Latency   fast fast
G.INP   on off
Bitswap   on on
Profile 17a
G.Vector   off off
Error Counter
  Errors (ES) Many
Errors (SES)
per
Minute
Last
15 Minutes
FRITZ!Box 1 0 0 0
Central exchange 519 0 0.19 0
RandallFlagg
Fixes: 75
Hi @daveg6hni
Thanks for the update - everything you've provided from the most recent test looks absolutely fine.
If you could keep an eye on this over the next couple of days and let us know if this is consistent, that would be great.
Best wishes
Dave
