GEA test
FIXED- Subscribe to RSS Feed
- Re: GEA test
11-10-2019 4:10 PM - edited 11-10-2019 4:10 PM
11-10-2019 9:15 PM - edited 11-10-2019 9:16 PM
Thanks for your post @smackay83
I've provided the GEA test below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 72.0 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 408.8 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | ;00:00to23:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 14 |
Home Wiring Problem | Not Detected |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
DP Type | External |
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2019-09-28T21:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 75.8 Mbps | 75.8 Mbps | 75.8 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 898.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-10-11T19:44:57Z | 2019-10-11T19:59:57Z |
Ingress Code Violation | 2 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Re: GEA test
11-10-2019 9:47 PM
Thank you. Is this anything to worry about
Re: GEA test
12-10-2019 6:32 PM
Everything looks spot on from this side IMO, are you seeing any issues your side that is concerning you?
Thanks.
Re: GEA test
12-10-2019 8:36 PM
No, I'm happy with my service. Just wondering what is causing the Regular Interference.
Re: GEA test
14-10-2019 9:28 AM
Hi @smackay83
Thanks for confirming - the line you've highlighted is nothing to be concerned about - it seems to be a staple on most of the line tests we run, irrespective of the quality of the line.
If you run into any issues further down the line, just let me know.
Best wishes
Dave
Re: GEA test
14-10-2019 1:31 PM
