GEA test please
graticus
GEA test please
could you run a GEA test on my line please and post the results here.
I am very interested to see what the value for: 'Estimated Line Length In Metres' is.
Thanks!
Moderators Note: Several replies bumping thread removed as it's against Forum rules
3 REPLIES 3
Fixes: 1,280
Re: GEA test please
Thanks for your post @graticus and apologies for the delayed response.
I've attached a copy of our testing for your line below. Everything looks fine to my eye.
GEA Test Detail
Circuit ID NA Service ID
[redacted BBEU]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 79.9 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 463.2
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ;00:00to23:45
Interference Location Customer Premise
Interference Observed In Days 14
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream 3dB, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2020-02-25T16:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 80.0 Mbps 80.0 Mbps 80.0 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 2.0 Sec 900.0 Sec 899.2 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2020-03-09T15:26:35Z 2020-03-09T15:41:35Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
graticus
Re: GEA test please
Thanks very much!
Fixes: 1,280
Re: GEA test please
No problem, let us know if there's anything else you'd need help with
