GEA line test
apollo1
GEA line test
Hi
Could someone from the plusnet team rune a GEA line test and post the results please
Interested in estimated line length.
On the fibre checker the line speed has increased from 38ish to 47mb over the years.
Wondering if my line has done a tour of the estate before it was rerouted and that’s why I can’t get anywhere near 70+mb
Originally on my new build we were meant to be connected to the cabinet very close to us (this cabinet still not got fibre (6 years now) but rest of the estate now is having FTTP installed over the past couple of months) but due to delays on the Openreach ground work our line was connected with some others houses to another cabinet (FTTC ENABALED) down the road. Did ask Openreach if they plan to put FTTP on my street but no plans to only the rest of the estate.
1 REPLY
Fixes: 188
Re: GEA line test
I've attached your GEA test result below
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 35.0 Mbps
Upstream Speed 6.2 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 899.3
Upstream Rate Assessment Reasonable
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-35M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2018-01-24T14:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 34.9 Mbps 34.9 Mbps 34.9 Mbps
Up Stream Line Rate 6.1 Mbps 6.1 Mbps 6.1 Mbps
Up Time 900.0 Sec 900.0 Sec 900.0 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-02-06T13:26:23Z 2018-02-06T13:41:23Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Matthew Wheeler
