GEA line test
- GEA line test
GEA line test
02-02-2018 11:14 AM - edited 02-02-2018 11:15 AM
Hi
Could someone from the plusnet team rune a GEA line test and post the results please
Interested in estimated line length.
On the fibre checker the line speed has increased from 38ish to 47mb over the years.
Wondering if my line has done a tour of the estate before it was rerouted and that’s why I can’t get anywhere near 70+mb
Originally on my new build we were meant to be connected to the cabinet very close to us (this cabinet still not got fibre (6 years now) but rest of the estate now is having FTTP installed over the past couple of months) but due to delays on the Openreach ground work our line was connected with some others houses to another cabinet (FTTC ENABALED) down the road. Did ask Openreach if they plan to put FTTP on my street but no plans to only the rest of the estate.
Message 1 of 2
(1,051 Views)
1 REPLY 1
Re: GEA line test
06-02-2018 1:46 PM
I've attached your GEA test result below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 35.0 Mbps |
Upstream Speed | 6.2 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 899.3 |
Upstream Rate Assessment | Reasonable |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-35M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off |
Time Stamp | 2018-01-24T14:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 34.9 Mbps | 34.9 Mbps | 34.9 Mbps |
Up Stream Line Rate | 6.1 Mbps | 6.1 Mbps | 6.1 Mbps |
Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-02-06T13:26:23Z | 2018-02-06T13:41:23Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Message 2 of 2
(997 Views)
