GEA line test request
- GEA line test request
22-05-2018 12:08 PM
Hi Plusnet,
Is it possible to request a GEA line test on my new FTTC connection?
Thanks,
Mathew
Thanks,
Mathew
Message 1 of 2
(397 Views)
1 REPLY 1
Re: GEA line test request
23-05-2018 2:42 PM
Hey Matthew, sure.
How has your experience been so far?
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 64.8 Mbps |
Upstream Speed | 17.7 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 601.7 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-05-21T09:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 64.8 Mbps | 65.6 Mbps | 65.3 Mbps |
Up Stream Line Rate | 17.6 Mbps | 17.7 Mbps | 17.6 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 740.1 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-05-23T13:15:34Z | 2018-05-23T13:30:34Z |
Ingress Code Violation | 1 | 0 |
Egress Code Violation | 36 | 31 |
Errored Seconds | 31 | 26 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Message 2 of 2
(355 Views)
