GEA line test request
bigshorty40
Hi
Could you perform a GEA line test please? I'm interested in the results as I've had a DLM reset done on my line, but I seem to be getting a lot of errored seconds, and wondering if the GEA test might throw something up.
Many thanks
Fixes: 385
Re: GEA line test request
Sure thing, here you go.
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 70.4 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 310.4
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
bigshorty40
Many thanks!
lzjoker
Can i grab one too as have had the engineer out yesterday and want to check the fault marker has cleared ok.
