GEA line test request
- Re: GEA line test request
24-07-2016 9:59 PM
Hi
please could someone complete a GEA line test on my account and then provide the results.
Many thanks
Mantaray
25-07-2016 10:28 AM
Here you go:
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 0.0 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 43.0 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Obviously that downstream sync is wrong. I'll run the test again shortly.
25-07-2016 12:29 PM
The gateway checker also fails to find which gateway I am at.
25-07-2016 12:35 PM
The gateway checker isn't related to the 0 sync showing. I'll test again now and see what I get.
25-07-2016 12:38 PM
It's still pulling back 0 for the downstream sync, however looking at the speedtest results you've provided the speeds you're getting are still pretty good and the profile is at just over 72Mb/s.
25-07-2016 1:34 PM
