GEA line test request please.
- Re: GEA line test request please.
20-01-2018 10:43 AM
Hi PN team,
Can I have a GEA line test done please.
Just want to make sure everything is ok since I had a connection drop a couple of weeks ago.
22-01-2018 3:01 PM
Hi there. Here you go (All looking good to me):
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 78.6 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 353.4 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-01-09T15:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 78.7 Mbps | 78.7 Mbps | 78.7 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 897.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-01-22T14:39:57Z | 2018-01-22T14:54:57Z |
Ingress Code Violation | 1 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
22-01-2018 8:20 PM
Thanks for doing that......all looks ok to me.
22-01-2018 11:44 PM
03-03-2018 8:33 AM
I seem to have had several connection drops over the last few weeks, can I have another GEA test done to see if anything has changed.
Also if your systems can see anything that might be off, then please let me know too.
03-03-2018 9:37 AM
Any chance i could have one done as the blue light on my router keeps flashing when i watch catch-up tv on youview.
05-03-2018 6:43 AM
Just bumping this request in case it was missed over the weekend.
05-03-2018 9:39 AM
@Malcky I've attached yours below.
Downstream Speed | 76.9 Mbps |
Estimated Line Length In Metres | 364.5 |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Time Stamp | 2018-02-20T09:45:00 |
Down Stream Line Rate | 76.9 Mbps | 78.2 Mbps | 77.5 Mbps |
Up Time | 864.0 Sec | 900.0 Sec | 899.8 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Start Time Stamp | 2018-03-05T09:09:24Z | 2018-03-05T09:24:24Z |
Ingress Code Violation | 0 | 3 |
05-03-2018 9:48 AM
@andytay And here is yours.
Downstream Speed | 40.0 Mbps |
Upstream Speed | 10.0 Mbps |
Estimated Line Length In Metres | 458.5 |
Technology | VDSL |
Profile Name | 0.128M-40M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off |
Down Stream Line Rate | 27.8 Mbps | 39.9 Mbps | 35.4 Mbps |
Up Stream Line Rate | 9.9 Mbps | 9.9 Mbps | 9.9 Mbps |
Up Time | 801.0 Sec | 900.0 Sec | 899.8 Sec |
Retrains | 0.0 | 3.0 | 0.0 |
Start Time Stamp | 2018-03-05T09:14:38Z | 2018-03-05T09:29:38Z |
Ingress Code Violation | 0 | 0 |
05-03-2018 3:43 PM
Thank you Matthew
05-03-2018 9:06 PM
Thanks for doing that Matthew.
06-03-2018 11:12 AM
