GEA line test request please.
Malcky
Hi PN team,
Can I have a GEA line test done please.
Just want to make sure everything is ok since I had a connection drop a couple of weeks ago.
11 REPLIES 11
Fixes: 1,600
Re: GEA line test request please.
Hi there. Here you go (All looking good to me):
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 78.6 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 353.4
Upstream Rate Assessment Very Good
Technology VDSL
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-01-09T15:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 78.7 Mbps 78.7 Mbps 78.7 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 897.0 Sec 900.0 Sec 899.9 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-01-22T14:39:57Z 2018-01-22T14:54:57Z
Ingress Code Violation 1 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Malcky
Thanks for doing that......all looks ok to me.
Fixes: 1,600
Aye, better than my 54mbps line. Smiley
Please let us know if you need any further assistance from us.
Malcky
I seem to have had several connection drops over the last few weeks, can I have another GEA test done to see if anything has changed.
Also if your systems can see anything that might be off, then please let me know too.
andytay
Any chance i could have one done as the blue light on my router keeps flashing when i watch catch-up tv on youview.
Malcky
Just bumping this request in case it was missed over the weekend.
MatthewWheeler
Fixes: 479
@Malcky I've attached yours below.
Test Outcome Pass
Sync Status In Sync
Downstream Speed 76.9 Mbps
Estimated Line Length In Metres 364.5
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Time Stamp 2018-02-20T09:45:00
Down Stream Line Rate 76.9 Mbps 78.2 Mbps 77.5 Mbps
Up Time 864.0 Sec 900.0 Sec 899.8 Sec
Retrains 0.0 1.0 0.0
Start Time Stamp 2018-03-05T09:09:24Z 2018-03-05T09:24:24Z
Ingress Code Violation 0 3
Errored Seconds 0 0
 Matthew Wheeler
MatthewWheeler
Fixes: 479
@andytay And here is yours.
Test Outcome Pass
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 10.0 Mbps
Estimated Line Length In Metres 458.5
Technology VDSL
Profile Name 0.128M-40M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Down Stream Line Rate 27.8 Mbps 39.9 Mbps 35.4 Mbps
Up Stream Line Rate 9.9 Mbps 9.9 Mbps 9.9 Mbps
Up Time 801.0 Sec 900.0 Sec 899.8 Sec
Retrains 0.0 3.0 0.0
Start Time Stamp 2018-03-05T09:14:38Z 2018-03-05T09:29:38Z
Ingress Code Violation 0 0
Errored Seconds 0 0
 Matthew Wheeler
andytay
Thank you Matthew Thumbs_Up
Malcky
Thanks for doing that Matthew.
Fixes: 1,600
On behalf of Matthew, no problems at all. Smiley
Please let us know if you need any further help.
